Results 1 to 10 of 21
Thread: Cruise Control... How do you work it?
    Regular Member lew1984's Avatar
    Jul 2011
    Cheshire
    Default Cruise Control... How do you work it?
    Hi everyone,
    Can someone simplify how you use Cruise Control on your car... like how to turn it on, adjust the speed etc?
    Only reason I ask, is that when im using it and I try to adjust the speed... it'll play silly beggers and will go off and wont come back on again until I turn the engine off to reset!
    Lew
    Full Member spennny's Avatar
    Blantyre
    U may have a dodgy switch mate, have a search on here there are numerous threads about it
    Before you use it have you already used the brakes , just a thought
    newport
    top button to turn on, then top button again to increase speed or lower button to decrease speed.
    back button or brake pedal to turn off
    bottom button to turn back on and automatically go back to the speed it was before it was turned off, or top button to set it to the speed you are currently doing
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I have a spate stalk here matey if u ever make it down u can have it any idea whennu will be here or I can come to you if you want
    Jul 2011
    Cheshire
    Quote Originally Posted by spennny View Post
    Yea i'm aware of the brakes bit... also a possibility could be dodgy... might be worth giving it a clean
    Quote Originally Posted by taffy bhoy View Post
    Yea thought so... I'm thinking I could be doing it wrong which 'confuses the system'... i'll keep an eye on it
    Quote Originally Posted by paulvectrac View Post
    Cheers buddy, i'll keep a closer eye on it and give it a clean to see if it'll do the job... if not i'll let you know
    Regular Member amand's Avatar
    Feb 2011
    west London
    I noticed that revs have to be above 1k otherwise it turns off. I was doing this 5th gear at 30 and cruise wouldnt stay on.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    Quote Originally Posted by lew1984 View Post
    Hi everyone,
    Lew
    when your driving with the cruise control on make sure you dont rest your left leg on the clutch or brake it will turn off cruise else
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    im glad we found that make of alloy ah paul
    Regular Member Exclusive BV's Avatar
    West Midlands
    if if turns off without any user input on the stalk or pedal then it could be the mechanism on the clutch malfunctioning. In normal operation you can press either the brake or clutch to turn it off. Try putting your foot under the clutch and pulling it up as far as it will go .... then try to re-ingage the cc
    Woodbridge
    The clutch spring is quick to fix if that is the problem.
  1. Cruise control.
    By Hyperhart in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 20:02
  2. Cruise control doesn't work!
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 23:39
  3. Cruise control doesn't work!
    Last Post: 29th October 2009, 20:56
  4. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
vectra c cruise control how to use
how to use vectra c cruise control
