Results 1 to 10 of 19
Thread: fog lights fitting
    Nov 2011
    Fife
    Default fog lights fitting
    I presume I could fit fog lights into a LS 1.8 2003 model from a higher spec model
    but what ones are the correct type as it seems there are square ones and round ones...so what type is correct and what else would I require to get them all working...not afraid to do any wiring or things like that, I presume I need to change the headlight switch plate as there is no button for front fog lights
    Engine : 1.9 CDTi
    What bumper do you have?
    Nov 2011
    Fife
    its the same as this one ...bit dark to take a picture of the actual cars bumper so just got this of the net....but exact same as this
    Nov 2011
    Fife
    anyone got a clue
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Ls bumper so ubwill need standard fog lights not circle ones
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Basically as long as you fit the non-sports bumper ones you're fine.
    These ones will fit
    These ones wont
    Nov 2011
    Fife
    thank you ...ebay shopping I go...I gather all I need is the two lights and a new switch panel
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    new grill for where foglights are...
    wiring for front foglights.. (notice that wiring for prefacelift/facelift isnt the same)
    Check you have wiring at the front plug. (near where the temperatur sensor)
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Fraz if you want it totally factory fit you will also need to change the fuse box under the bonnet(UEC), for one from a preface Elite or Sri. Theres a module built into the underside of the circuit board on the ones from the higher spec models, then you will also need a tech2 or opcom session to activate them too. I'm now on my 3rd fusebox trying to crack this and still had no luck. I have mine wired in the old fashioned way with a relay in battery box area and button on one of the spare blanks on the dash. Ill get this cracked one day. You don't actually need new grills, you can modify the original ones with a hacksaw.
    Nov 2011
    Fife
    Mmmmmmm older cars are much simpler lol (bit like me )
    so I can fit them but I cant actually have them working by just simply changing the switch panel and installing the lights
    I thought that they would simply use the top spec wiring harness for all cars so the wiring would be there behind the front grill and switch panel
    they make it harder these days to upgrade your cars specs
    So they old fashioned way it is I think as changing fuse box's is a bit of a pain as is getting a hold of a Tech2 to get them working, but at least they will look ok from the outside
    thank you again guys ...may have to go and visit the scrap yards I think to get a few things...ebay is just more convenient than trawling round a scrap yard ..and its also saves my time
  1. Fitting fog lights
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2011, 11:17
  2. Fitting new head lights
    By IWC in forum Bodywork & Interior
    Last Post: 28th August 2011, 20:54
  3. fitting new brake lights...
    By admob in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 21:35
  4. Fitting LED boots lights
    By mickydoos in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2010, 15:12
