Results 1 to 10 of 13
Thread: Help with High Pressure Pump Z19DTH
    Redcar
    Default Help with High Pressure Pump Z19DTH
    1.9 Sri High Pressure Fuel Pump guide anyone and is it coded? Mine has failed supposedly
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi i dont think they are coded i do have 1 sitting here on a low miles engine pm me if intrested
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    see mate i told u alwys someone to help
    Redcar
    Do you know how hard they are to fit? My car just died the other day on way back from shops and RAC man is 90% sure its the fuel pump.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    hi not to bad to fit you put 2 bolts through th pulley so no removing timing belt then 3 nuts bolt pump on have a look at the how to for inlet manifold as pump has to be taken of for that.
    Redcar
    Would the car then work or does it need a computer plug in to get it to work. Ive got a halfords pro tool kit would that be all I need? I would be a newbie to be honest. Iam just hoping a swap would fix my car. Appreciate your help :-)
    leicester
    Trim : Sri xp2
    Mileage : 100000
    no computer needed
    Redcar
    Would i need jack engine up or could i do it all from the top. Take timing cover off put bolt through to keep pully postition then unbolt and change pump. Iam not sure which steps i can miss with that how 2.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Think it should be jack up car, remove engine mount. remove timing cover, replace engine mount if you want. Put two bolts into the high pressure pump pulley/sprocket (as per how2). Then follow the bits on the how2 to remove the pump (think the vacuum box should be in the way though). Dont forget to catch the woodruff key....
    Halfords pro kit is plenty sufficient to do it
    Redcar
    Do I need to jack up car or just engine and where do I get these bolts from? Is the vacuum box simple to remove. Without the bolts does the pulley fall off? I think I might be able to do this like :-D The car just dyed without warning while driving and the RAC man plugged a computer in and he said he 90% sure its the fuel pump. Is there any other possible things? Cheers for your help mate
  1. High Pressure Fuel Pump
    By trevteah in forum Engine & Drivetrain
    Last Post: 9th October 2010, 19:09
  2. High pressure pump leaking!!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 21st November 2009, 22:14
  3. air con and high pressure fuel pump
    By dayna1501 in forum Introduce yourself.
    Last Post: 23rd June 2009, 18:52
  4. High Pressure Fuel Pump
    By nesbigr0 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 17:08
  5. High pressure pump failed
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2008, 12:23
