Thread: Bleeding a Signum 3.0 CDTI V6 facelift?
    Aug 2010
    Birmingham
    Default Bleeding a Signum 3.0 CDTI V6 facelift?
    Changed the diesel fuel filter and now can't get the car started
    Anyone know how i can bleed the system get the air out?
    Make sure the housing is full before resealing
    Crank the engine no more than 10 times, then stop
    Repeat
    It shouldn't take more than 3 times
    Allow the engine to idle for about 90 seconds
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Take the lid off again and pour derv slowly into the middle of the filter (in situ obviously) through where the bolt goes right to the brim.
    Refit lid, carnk over as m8internet says and when it catches put the throttle to the floor for a few seconds. It may well still cut out after doing this (mine did last week) but persevere .
    Aug 2010
    Birmingham
    cheers guys - will try but now i have a flat battery
    trust my luck
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Crack an injector pipe a bit and crank the engine. When you see diesel dripping out of the nut, tighten it back and crank the engine again. This should help..
    Aug 2010
    Birmingham
    Thanks for the advice guys. Luckily my mate popped by with his car and we had to use the jump leads and managed to get the car going after a few tries Since we failed with jump leads with my neighbors 1 litre fiesta - not enough juice and he said he car was smoking.
    So glad that it doesn't need to go to the garage.
  1. Bleeding Flat Spot is back! Usual CDTI 150 Suspect!!!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 19th April 2011, 17:04
  2. Signum facelift cdti 150 and tuning box
    By wadep509 in forum Diesel Engine related
    Last Post: 2nd June 2008, 01:31
vauxhall vectra 3.0 diesel fuel filter bleed
vectra 3.0 bleed diesel system
