Results 1 to 10 of 11
Thread: Wub Wub Wub noise
    Feb 2011
    North East
    Default Wub Wub Wub noise
    It's not often that I drive without the stereo on however I was doing that on Friday night when I dropped the other half off in town.
    Anyway I can now hear this noise which seems to be coming from somewhere at the back of the car.
    It sounds like a wub noise and the faster I go the faster the wub goes
    wub wub wub wub wub....it's not loud but I can hear it.
    Nothing wrong with the tyres so I'm not sure what the problem would be.
    Brakes? Wheel bearing?
    Any ideas?
    Regular Member nicj's Avatar
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Sounds very much like something is stuck in one of your tyres
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    What tyres have you got on I'm getting the same drives me mad
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Not Jonathon Ross stuck in your tyre?
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    I had this problem 2 weeks ago and it turned out to be my passengers side rear tyre worn out quiet badly on the inner edge, didnt notice at first but then had a closer look with the wheel off.
    Changed that tyre and its gone alot quieter now but the noise is still there "Wub Wub Wub" Alot less louder than before. So am guessing its going to be one of the other tyres, though i cant spot anything on the other tyre?!?
    Garage said it might be a wheel bearing but cant locate which one it might be and just said let it get a little worse and then get it checked again.
    watching this thread as this noise is really annoying
    Well, let's start with the obvious
    What tyres are fitted?
    How old are they?
    What is the tread wear like on them?
    Inspect the tyre, across the tread and at each quarter (no need to raise just move the car)
    Next, raise the rear of the car and fully inspect the tyre and wheel
    Check for punctures, debris, etc
    With the car fully secured, release the handbrake, spin the wheel
    That pretty much covers the tyre, wheel, brakes, and hub
    Next you want to check the suspension and springs
    The easiest way is to drive slowly over a speed bump (the type that is across the entire carriageway lane)
    If the rear of the car wobbles side to side, then it is a shock absorber or spring
    Run through the above steps and post accordingly
    Feb 2011
    North East
    Cheers for the replies.
    The car has 215/50/r17 Goodyear NCT5s all round.
    They all have good tread across the width except for the front passenger side which has low depth.
    I've been over a few speed humps as there are plenty in the nearby streets and the car seems fine going over them. No other noises to tell of.
    I've just purchase some new wheels from work as this guy was looking to offload and I needed at least one tyre (but prefer to change in pairs. So I've got some 225/45/r17 astra turbo wheels to put on with Vredestein Wintracs all round to see if that makes a difference.
    Just waiting for my new disk and pads to turn up.
    I was just trying to guage if this was going to be an expensive fix aka wheel bearing.
    Guess we'll find out more when I get the wheels changed...
    Regular Member Exclusive BV's Avatar
    West Midlands
    If there is no nail or screw found embedded in the tyre
    then my monies on an out of shape tyre.
    You know the type, old with cracked walls and gone rock hard
    West Midlands
    <duplicate post> mods please delete
    Quote Originally Posted by zappakat View Post
    You advised the noise was coming from rear, so only refer to this
    Take a look at the (rear) tyres and find the four digit year code, should end 09 10 or 11
    NCT5 tyres, where were these manufactured?
    As above fully inspect them (not just as described as above) visually first and then physically if nothing untoward is found
    When you replace the front tyres, swap the rears to the front
    This will wear them out, rather than having older tyres at the rear for a long time
    Equally, see if the noise swaps from the rear to the front
    If not, then the issue is most likely with the rear hub
    When was the alignment last checked (and corrected)?
    The rear is known for being horrendously incorrect from factory and requiring adjustment
    However, the usual sign of this is wear on both inside or outside edges of rear tyres, and once the tyres are down to 3mm horrendous noises
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
