Thread: heater fans not blowing
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    Default heater fans not blowing
    evening all,
    recently my heater fans have stopped working, as a added bonus they stopped in fan speed 0 so unable to tell if its the resitor or the fan motor itself.
    i have a gsi so have the fully electric fascia....just wondering what checks i can do, where to locate components etc isit a pain?
    anybody able to help? thanks...Jaspa!
    is it normal heater or climate control
    the fan motor is located behind the glovebox
    check under you scuttle panel to see if the drain tube is blocked
    if it is there will be a lot of water then youll prob find the water has ingressed through your pollen filter and flooded the fan
    if its a normal fan it should still work on number 4 if its the thermal fuse if its climate control then none of the settings will work and it will be the regulator at the bottom of the fan unit
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    pollen filter i havnt long changed...it all looks good, and its the climate control i believe so im going to be looking at this regulator yea? sounds expensive
    take pollen filter out and you will see the top of the fan
    make sure that the fan rotates ok
    if the fan is ok and there is power to the climate control unit under the radio ( i.e the lights are on ) then yes its 99% chance that the regulator has gone
    its a grey unit located at the bottom of the heater motor
    now the bad news , its £176+vat from the dealers
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    well the filter is fine, fan is free, lights around the fascia all ok jus no fans at all, took the resistor out n theres abit of fluff round where it slots in but looks like some of the solders have broken inside
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    by fans free...should it freewheel? i can push it round with my finger but it doesnt keep spinning...and the mess on the plug suggests ingress i may be going for the lot...oh great at xmas time too...!
    Fan sometimes freewheel but as long a it's free it should be ok looks like a new regulator is needed have pm'd ya
    Sent from my iPhone using Tapatalk
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Did you find out what this was mate? I have exactly the same problem
  1. Heater constantly blowing hot!!!!!
    By axelf in forum Engine & Drivetrain
    Last Post: 29th March 2011, 16:44
  2. Heater only blowing cold air
    By Chilie in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 18:26
  3. Heater only blowing Hot Air
    By DaveVectraSRI in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd February 2009, 15:47
  4. Heater blowing cold.
    By neilgsi in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2008, 17:48
  5. Fans not blowing?
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2007, 21:24
