Results 1 to 10 of 13
Thread: Steering rack AGAIN !
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Default Steering rack AGAIN !
    When under the car afew days ago, noticed that the steering rack was wet around both gaiters with power steering fluid. Been to the dealers today to price up a pre tensioner kit and asked for a price on the rack aswell (wasn't going to buy one from them, just curious). The guy on the parts counter said if its wet around the gaiters, it just needs new tie rods and these are sold seperatly at £25 each with the VAT and service club discount.
    Has anyone had the same with the tie rods and are they easy to do ?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Not heard that one before fella
    Fil it's prob not ps fluid it's probably the grease inside the gaitors that lubricate the inner tie rods
    Easy job they just unscrew and screw new one one , whole
    Your at it change track rod ends as well as you have to take them
    Off to
    Change inner tie
    Rods
    Sent from my iPhone using Tapatalk
    Mileage : 000
    Phil. I saw a tool on ebay that is usefull when taking off the inner tie rod, might be worth getting one of those.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Ed, is that a tool which goes over the whole length of the steering rod right to the inner joint?
    Mileage : 000
    A sort of circular looking thing, not unlike some "pipe cutters" I have seen. You put the tool over the tie rod there is a knurled wheel that when you turn the tool it digs in and allows you to hold it still.
    Quote Originally Posted by plasma View Post
    dean can see that working as the ball at the end of the inner tie rod is usually larger than the nut you have to undo
    Quote Originally Posted by ed taylor View Post
    and ed you can twist the tie rod as much as you like but when the ball joint is worn the ball will just turn in its housingand wont undo it
    best way is a correct size spanner on the nut at the end of the steering rack , i believe its 36mm
    Mileage : 000
    Mark I see where you are coming from. But here is a link to the tool I had in mind. Dean (plasma)have a look here.
    http://www.ebay.co.uk/itm/Multi-Purp...item415f215c1b
    i can see it fits quite large sizes and a good range of sizes ed so probably goes straight over the nut on the tie rod
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by marktaylor View Post
    It's wet rather than greasy Mark.
    You could make something like that Ed !
  1. Steering Rack!!
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2012, 23:02
  2. Steering rack help
    By dittohead in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 19:10
  3. Need a new steering rack :(
    By Xerath in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2010, 17:44
  4. Steering Rack
    By rob1964bike in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2010, 14:27
  5. Steering Rack
    By maxd cavy in forum Engine & Drivetrain
    Last Post: 26th June 2009, 09:21
vectra c steering rack gaiter wet
