Thread: Interior lights question. Please help.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Question Interior lights question. Please help.
    My interior lights have stopped coming on when i remove the keys from ignition or open the doors. The interior lights all work when using the switches. The dashboard tells me the door is open when the ignition is on so I know it's not the door switches. Can anyone shed any light on this problem please?
    Paz.
    Regular Member farley2708's Avatar
    antrim n.ireland
    same happened to me mate,thought i had damaged the loom when looking for to see if i had the connector for the rear interior light,checked the loom no broken parts in the ribbon,so fitted a new 1,problem solved £20 but still confused as i couldnt see any damage,so now this all works
    Jul 2011
    UK
    Year : 06
    Try the rear passanger bulb not blown if you have one its strange I know but happend to me and was going mental as wasn't working tried everything
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Bump?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Quote Originally Posted by marc vectra sri View Post
    Actually my rear passenger brake light bulb has blown twice recently. Just changed the bulb this morning. But I'm still having the interior lights issue. How did you solve it?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Bump.
    Jul 2011
    UK
    Year : 06
    Not brake light the interior light do u have one in the rear on roof take it out check the bulbs and conections are straight
    Regular Member clairey83's Avatar
    Nov 2011
    Dumfriesshire
    Engine : 1.9cdti
    Mileage : 155000 :o
    Not sure this is the right sections but fingers crossed...
    What way are the 2 buttons on my interior light meant to be switched to have the light come on when the doors open?
    I'm sure my daughter pressed one earlier to see putting her seatbelt on and now when I shut and lock the car the light stays on. I've pressed the buttons different ways but the light is either constantly on, or constantly off!! Which way should the 2 switches be set???
    Claire.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    theres one for light constant on.. (then the light will be on even when doors closed and you drive off ect) the other button turns the front lights off when the doors are open..
    but press both, and you will still have light.. but surely.. they stay in when pressed.. so just depress them...
    Nov 2011
    Dumfriesshire
    Engine : 1.9cdti
    Mileage : 155000 :o
    Turns OFF when the doors are open? I thought it would come on with the doors being opened. Maybe that's where I'm going wrong
    Think I'll have another investigation in the morning!
  1. DIY Map lights, Interior lights Off button console?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 10:35
  2. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  3. Interior map lights question
    By Gubmint Agent in forum Styling
    Last Post: 28th March 2011, 19:00
  4. No instrument lights or interior lights.
    By RykuZ0 in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2010, 23:55
  5. Interior lights question...
    By abbeytec in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 16:20
