Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi to everyone but does anybody know if service would make that much difference to my fuel consumption as i dont think im getting what i should hope somebody can help
    Regular Member Thom's Avatar
    Nov 2010
    UK
    What are you getting?
    in my 2.0dti i get about 40-45mpg mixed driving. with 2 stroke added i get abotu 600miles to a full tank, however many litres that is.
    Jan 2010
    norfolk
    Default vectra dti
    my fuel light come so i put £10 in and done about 52 miles before light came on this was a mixturer of town and open road
    Jan 2010
    norfolk
    iv also got fault with one glow plug not working but somebody tryed to get it out and ******ed it up they have put some sort of filler in to hold it in how can i get this out without removing head
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    The missing glow plug wont effect your MPG as they are only used for starting the engine when its cold.
    It could be worth a service if it due but dont forget the little things that we al forget such as correct tyre pressure and making sure the oil level is good.
    Does your temp gauge work correctly i.e. getting up to running temp and not dropping when heaters are switched on on going fast.If so then it could be a duff thermostat,ive just changed mine for exactly the same reason.
    Dont forget as winter creeps in that ull be using the heaters and probably driving when its dark more so headl lights will be on which uses more fuel.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Quote Originally Posted by octoman View Post
    thats the same as my siggy elite auto 2.2 direct i get 106 miles for 20 quid
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
