Thread: Hid problem help please MOT tomorrow!
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Default Hid problem help please MOT tomorrow!
    Having a problem with one of my hids, think it's the ballast but not 100% sure
    Basically it's coming on for a few seconds then switching straight off and or come back on till I restart the car. Also when the ballast shuts down the car cuts the power to it. Tested with a multimeter and it was showing 0.23v, is this the canbus system doing it's job?
    Doin my head in and the mot is tomorrow morning so of anyone can help please do....
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Sounds like u need a new ballast fella have u tried switching the one from the other side and see if it still does it?
    Oct 2010
    middlesbrough
    Yea I've switched them and it's still doing it, so I reckon it's the ballast. Just seems weird because sometimes it'll stay on for ages but most of the time it just cuts out straight away. I'll get a new ballast ordered and see if that helps.
    Does anyone know why the car stopped sending power to the lights when the ballast shuts down?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by benholden2010 View Post
    You've just answered your own question there fella.
    Oct 2010
    middlesbrough
    So because it triggers the low beam warning light it stops sending power to in until you restart the car? I never new that I would of thought that they should always be 12v at the light aslong as there switched on?
    Oh well looks like I'll be taking them out in the morning before mot:@
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    No its the other way around. The canbus system sends a pulse around the car measuring the resistance of the bulbs, because the ballast fails it can no longer measure the resistance of the bulb that's not working so thinks that the bulb is gone and triggers the failure message.
    Oct 2010
    middlesbrough
    Ohhhh I see, well hopefully a replacement ballast will sort it
    Regular Member coooky's Avatar
    May 2011
    washington
    you might also need cancelers i had to fit 2 to my drivers side to get it to work
  1. MOT tomorrow
    By John LE in forum General Motoring Chat
    Last Post: 11th May 2012, 18:10
  2. Before i start tomorrow whats the common problem
    By daveypower in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 20:47
  3. New Car Tomorrow!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 00:56
  4. MOT tomorrow
    By BoroDave74 in forum General Chat
    Last Post: 15th May 2009, 22:06
  5. Sad Day Tomorrow
    By WHOOSH05 in forum General Chat
    Last Post: 11th January 2008, 02:25
