Thread: Signum satnav cd70 question
    Oct 2006
    Suffolk
    Default Signum satnav cd70 question
    Is it possible to be using the satnav CD70 without the radio or cd player on
    I cant see any way apart from just turning the volume down
    Any ideas ???
    Oct 2006
    Suffolk
    Sorry guys ive found the answer, you press and hold in the on/off button and it then says Mute volumeMart
    Oct 2006
    Wellingborough
    Good tip, thanks!
    Nov 2009
    Chester
    Thanks for this - had my 05 V6 Aga from new and never worked this out.
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Holding the on/off button pressed for three seconds turns the MUTE on
    Pressing the on/off button turns the MUTE off again afterwards.
    The radio will not be muted whenever you turn the headunit on, so you would need to go through the muting procedure everytime you use the navi system only, as described above.
  1. New POI on CD70 SatNav
    By Joneseylah in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2011, 01:34
  2. CD70 SatNav
    By 1.9Cdti Elite in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2009, 19:49
  3. CD70 satnav Bluetooth question
    By jsr645 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2009, 14:23
  4. Signum CD70 Sat Nav question
    By fishphone in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2007, 15:45
