Thread: Had enough of this ****** car now!
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Had enough of this ****** car now!
    I just cant believe these damn vectra's are so much trouble!!
    Ive always kept an eye on the swirl bar and my most recent examination was about 4 days ago while checking oil.The bar was on fine with just a tiny amount of dry gunk around the 4 swirl pot.
    I checked today and the 4th swirl pot is soaking wet with oily gunk and had jumped off the bar and is poking out about 5mm out of the hole.The 2nd swirl pot is starting to lift out about 2mm and the 1st is looking very loose.
    From what i can make out its the vibrations from the engine(very shaky and sounds like a tractor) has shaken them loose.I didnt really notice how bad it was untill i compared it to another vectra today
    There is also a hissing sound comming from the back left of the manafold which i cant quite locate accuratly due to the noise of the engine.
    Along with the 28mpg im getting and the constant buzzing through the pedals(assuming its the engine vibrations) i doubt ill still have the car at xmas.
    Just cant believe it becasue this was my dream car and couldnt believe it was actually mine sat outside my house.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Sorry but you bought a 1.9 you must of know the manifold will nee doing
    Aug 2011
    Basingstoke
    Trim : SRI
    yes i did know there was a good change it would need doing but the car isnt that old and only done 67k.The rate that it deteriorated was alarming...matter of a few days infact.
    Its a shame coz i love the car aswell as hate it.It woudnt bother me as much if i didnt have the Poor fuel consumption aswell.
    Regular Member Innes's Avatar
    Plymouth
    does the vibration through the pedal stop when you press the clutch? If so your DMF is on its way out.
    As for the fuel consumption when was it last serviced?
    This hissing could be a split intercooler hose which would give you bad MPG as well as some smoke out the back.
    May 2011
    bispham, blackpool
    get a warrenty wait a few week and get it all sorted out
    Aug 2011
    Basingstoke
    Trim : SRI
    Quote Originally Posted by Innes View Post
    no mate the vibration doesnt go when i press the clutch pedal in.
    The hissing sounds seems to be comming from the back of the engine bloack and to the left....above the alternator
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Get the manifold changed and you'll be amazed what a nice car you have again!
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by justin32 View Post
    Probably a shot manifold flap seal (the bit which rotates), it can lose boost pressure from there. Happened to a car I worked on.
