Thread: Scangauge 2 for 2.0 Turbo
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Scangauge 2 for 2.0 Turbo
    I bought a Scangauge 2 for my Astra Sri T but I sold the car. Will this work on the Vectra C 2.0 Turbo engine? What will it be good for it it does work? Thanks
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    its generic Mark and will be fine, they work on any eodb car..
    Feb 2006
    North East Uk
    Cool, I have it sat here brand new in the packet now. I just need a Vectra to fit it onto lol. I wonder if it will read the AFR on the Vectra, as on the Astra it would not work. Something to do with it not having a sensor for it on the Astra
    Jun 2009
    South Coast
    you can try to wire it up to one of the lambda sensors but i wouldn't as these gauges normally need a proper wideband sensor otherwise they are suppling bad info..
    You can buy a wideband afr from many places, get a garage or exhaust place to tap into your exhaust and weld in a lug with plug that you can fit the AFR to.
    Feb 2006
    North East Uk
    I should not have anything to worry about if I am only going to Stage 1, thats what I think I am only going to at the moment
    Jun 2009
    South Coast
    its not an essential piece of kit, its only really needed if you are doing to some major tuning to make sure you are not running lean when you are at higher rpms.. you can check these figures yourself if needed with a laptop plugged into your odb socket while you drive along..
    Jan 2006
    Dalriada
    What software do you need for the above Nige?? The unmentionable one?
    Jun 2009
    South Coast
    Quote Originally Posted by Steven View Post
    yes mate, that's one that will do it.. I have done it with that one.. you can record a run and see what your figures are over a graph on some others
    Jan 2006
    Dalriada
    Cheers buddy
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. People with Scangauge
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2011, 17:26
  3. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  4. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
