Results 1 to 10 of 15
Thread: Reading the dipstick - 1.9 150
    Regular Member AlexGSi2000's Avatar
    May 2011
    Liverpool
    Default Reading the dipstick - 1.9 150
    Just wondering if you guys have any tips for reading the dipstick on the 1.9 150?
    I pretty much get random readings from day to day.
    I checked yesterday, it was sat right in the middle - checked today and it was on max.
    That was after leaving the car for two hours.
    Also, there seems to be oil all over the dipstick towards the bottom, which makes matters worse! lol
    Sep 2010
    mine ALWAYS sits right up the flexible section by over an inch... it's never been on or between the flat dip section since the 4 services I have given it... useless
    Feb 2011
    Selby
    I don't know about the diesels, but on the petrol Vectra Cs, there's a label on the slam panel that tells you the procedure for reading the dipstick. Run engine up to normal operating temperature (about 80C), then switch off. Wait 5 minutes and then read the oil level.
    The dipstick is calibrated for the engine in that state - hot, but not running.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Let it stand, remove dipstick & clean, replace fully wait a minuite or so then check.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Run engine to normal operating temp. Turn off, and wait 5 min. Wipe dipstick clean and then reinsert for correct reading.
    Top up if needed.
    Regular Member Geo77's Avatar
    Sep 2009
    North Yorkshire
    Feb 2011
    Selby
    Same as the petrols then
    Most cars you check with a cold engine, but GM seem to have moved to check with a hot engine for some reason. Probably due to the thinner oils in use these days or something...
    May 2011
    Liverpool
    Thanks for the advice!
    Aug 2010
    Derbyshire
    My Mazda's engines dipstick seems as unreliable as the one in my CDTi. Can never seem to read it with a defined level, hot or cold.
    I thought that it's checking the sump level, so left overnight should read correct. It may do but it's bad design means as it's withdrawn you can't tell whether it's correct or not. Could be me but apart from my Mazda and now the Vx I've never had as much trouble deciphering whether it's needs oil or not.
    Mick
    Aug 2010
    Derbyshire
    Quote Originally Posted by Graham View Post
    Top up if needed.
    As per my post above I stand corrected. As you say Graham, I've just tried this method and it's spot on. Never really have had a truer reading on the dipstick before.
    Mick
  1. Dipstick
    By bigmac in forum Insignia car chat
    Last Post: 2nd July 2012, 21:38
  2. Oil Dipstick Help
    By Yohan in forum Engine & Drivetrain
    Last Post: 7th April 2012, 22:04
  3. Dipstick oil levels?
    By PeterVV in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 01:01
  4. 2.8 V6 - reading the dipstick
    By stampede in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2010, 16:32
  5. Reading dipstick on a 1.8
    By JuzzyD in forum Engine & Drivetrain
    Last Post: 8th November 2006, 22:40
https:www.vectra-c.comforumshowthread.php149940-Reading-the-dipstick-1-9-150
how to read vectra dipstick
trouble reading dipstick vectra
