Results 1 to 10 of 16
Thread: Fuel filter replacement - Y30DT.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Fuel filter replacement - Y30DT.
    Following M8Internet's post in another thread http://vectra-c.com/forum/showpost.p...27&postcount=6, I feel that now is a good time to replace my fuel filter.
    But how? As Haynes doesn't cover this, I'd be working blind. I know it's a paper type insert but can anyone give me a step by step guide as to how it's done, especially the bleeding operation after the new one's in.
    Looking forward to any pointers .
    Aug 2009
    Ascot
    Quote Originally Posted by gtr1000 View Post
    Mate it is a 5 min job, the black case with the filter in is at the back right of the engine. There is a Allen bolt in the top which you take out and remove the lid to reveal the filter.
    The main concern is upon re fitting, fill to the top with diesel and fit lid really tight, then again pour diesel into bolt hole before re fitting bolt.
    That's is that, I have changed mine twice and second time took me 5 min start to finish
    Nick
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you seen the price of the fuel filter for the 3.0 diesel is it gold plated or something lol
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    I thought both of these were quite reasonably priced . http://www.eurocarparts.com/fuel-filter
    Don't know what the difference is in quality between the two though.
    Aug 2009
    Ascot
    Mine from euro car parts is £8
    Nick
    What is the part number and I will check previous receipts
    From memory it is about £18
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The expensive one is the oil filter
    Replacing the fuel filter is not a big issue, but I would suggest you do it with a warm engine.
    Remove the filter housing and clean it out with a detergent of your choice, flush with water or whatever and wipe it dry (make sure to get all the water out). This was recommended to me by the Opel garage I use - you will see black deposits of dirt at the bottom. After successfully cleaning the housing, refill it with fresh diesel (or two stroke oil!) put the new filter element in and the lid on. The engine should start quickly when it does bury your foot to the floor (that's why it the engine has to be warmed up) to draw the fuel.
    Good luck.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Celes View Post
    Good luck.
    Hi Celes, just read your post AFTER I changed the filter. All went well apart from when I took the lid off, derv peed out all down to the bottom engine cover . I didn't disconnect the hoses on the lid but managed to hold the lid out of the way whilst I filled the chamber with derv.
    Started first time, then cut out. 30 secs of cranking (engine was warm ) and engine fired up and ticked over nicely.
    Old filter looked OK. I thought a change of filter might have helped my misfire at small throttle openings but problem's still there. Guess I'll have to start another thread .
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    No worries mate next time you get the filter out, remove the housing too and give it a clean
    These engines are simply **** (or in case it gets censored, cow excrement). Misfire here, misfire there. New filter - doesn't help, new SCV's - don't help, new injectors - don't help. I'm slowly fed up with it...I managed to reduce misfires to a minimal, but I can sometimes still feel it.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    So where do you think I should start .
    I was going to spray a can (or two) of Wynn's EGR3 into the motor and go from there.
  1. Fuel Filter Replacement - Z30DT
    By ph67 in forum Y & Z30DT Specific
    Last Post: 23rd August 2015, 13:45
  2. What is it with the Fuel filter on the Y30DT?
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 10th November 2012, 19:18
  3. 1.8 Petrol - Fuel Filter Replacement
    By wafoo in forum Engine & Drivetrain
    Last Post: 7th August 2012, 16:09
  4. Y30DT Fuel Filter Replacement Question
    By Antz in forum Engine & Drivetrain
    Last Post: 20th April 2010, 16:44
  5. Fuel Filter Replacement
    By Dedrater in forum Engine & Drivetrain
    Last Post: 13th June 2008, 07:56
vauxhall Y30DT diesel fuel filter change
