Thread: 1.9 cdti 120 antifreeze
    Regular Member Paddy's Avatar
    Mar 2011
    South East
    Default 1.9 cdti 120 antifreeze
    Hi
    Would it be ok to use normal blue antifreeze in my 1.9 cdti 120 to do a coolant change as do not know when it was last done.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    Quote Originally Posted by Paddy View Post
    Hi
    what colour is in you tank now?
    6 Post(s)
    Realistically you should be using the long life stuff.
    Just goto your local Vauxhall dealer and buy the correct stuff that they recommend. It's not going to be that expensive, as per a lot of the other service items.
    It's often a misconception that service items are expensive from the dealer - most of the time they're as competively priced as the other motor factors.
    Mar 2011
    South East
    Thanks for the reply's guys what it is I have 4 litres of blue antifreeze & 5 litres of Halfords 10/40 synthetic diesel oil & as not doing much tomorrow would like to a service as have the filters also.
    What do you think as if I do not use them then there going to go to waste.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    about 3 months ago i went in to vauxhall to buy some genuine gm vauxhall antifreeze i asked for the one for my 1.8 vectra they gave me the red/orange 1 litre bottle
    i already had the red/orange originally from new in the tank
    part number 93170402
    it is longlife and goes down to -38
    mix 50 percent water and 50 percent antifreeze
    about 4 pounds
    what colour is in the your tank?
    Mar 2011
    South East
    Quote Originally Posted by vectra ste View Post
    about 4 pounds
    Thanks for the reply it looks pink red so do not know if I should use blue now.
    Full Member Big Sig's Avatar
    No don't use the blue it's not suitable. A simple search on here will answer that. It's also a bad idea to mix them even if one has been flushed.
    The red/pink stuff is good for five years, if you don't know how old it is then get it changed. Better safe than sorry.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Do not use the blue stuff, it went out with Noaks ark pal, only suitable for mk1 escorts and the origional Mini these days. The red stuff only costs about £1 a lt more than the blue stuff but lasts much longer and has specific anti corrosion properties. As Big Dave and Ste say go to VX for it, its as cheap from them as it is from any motor factor and you know its the proper stuff. You'll need about 3lt to get a good strong 50/50 mix, Maybe someone could tell you exactly how much the 1.9 takes.
  1. Antifreeze in CDTI 150
    By WeDesign in forum Diesel Engine related
    Last Post: 20th February 2013, 09:24
  2. Antifreeze
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 17:16
  3. Antifreeze
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 23:21
  4. AntiFreeze
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2011, 14:18
  5. 1.9 CDTI loosing antifreeze
    By Maxim007 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:40
https:www.vectra-c.comforumshowthread.php149885-1-9-cdti-120-antifreeze
vectra c 1.9 cdti antifreeze
How much coolant does a vectra 1.9cdti take
vectra c 1.9 120 losing water
antifreeze for vauxhall vectra diesel
vauxhall vectra c 1.9 cdti 150 antifreeze
vectra c antifreeze
zafira cdti 2010 coolant
vectra c 1.8 coolant replace site:www.vectra-c.com
astra 1.9 cdti 06 what coolant
summer coolant vectra 1.9 cdti
coolant mixing in engine vectra 1.9 sri
1.9cdti use pink coolant
what anti freeze for a vectra
which coolant 1.9cdti
vauxhaull vectra c coolant
vectra c antifreeze amount
vectra 1.9 cdti coolant change
where do I put antifreeze in my vectra cdti
antifreeze for vauxhall vectra 1.9 cdti sri
