Results 1 to 10 of 25
Thread: fuel isue on 2.2 direct signum
    Nov 2011
    glasgow
    Default fuel isue on 2.2 direct signum
    iam still trying to get my car started it has sprk but not getting fuel ...from main fuel pipe i disconected and when ignition on no fuel comes out even when i crank the engine thare is half a tank ov fuel in it.. i have checked all fuses and relays to no avail .. i got a fuel pump tank side off vectra c 2.2 direct incase its that but on the vectra c you can get acces under the seat to change but not on the signum take it i will have to drop tank anyone had an isue like this help apreciated thankyou
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Have you checked the HP fuel pump on the fuel rail mate. The HP pump and the reg are a major failure point in the 2.2 direct.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    check high pressure fuel pump mate
    Nov 2011
    glasgow
    should i not get fuel up from the low presure side with feed disconected apresiate the info guys
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The lifter pump should still supply to the HP pump.
    Nov 2011
    glasgow
    priced the high preasure today and the presure regulator nearly fainted lol
    Nov 2011
    glasgow
    thats what i thought rushy thare should be fuel coming from the low first
    Nov 2011
    glasgow
    think i have to drop the tank just hope the one from vectra c will fit
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Why you droppin the tank
    Nov 2011
    glasgow
    i just hope its not an ecu fault
  1. Signum 2.2 `Direct' - fuel injection pump problem
    By omega2498 in forum Engine & Drivetrain
    Last Post: 20th August 2015, 19:06
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Signum 2.2 direct misfire - fuel pump?
    By jgs1000 in forum Engine & Drivetrain
    Last Post: 4th May 2012, 05:33
  4. Odd Fuel Consumption 2.2 Direct Signum
    By bebrox in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2010, 11:11
  5. Another Signum 2.2 Direct fuel injection pump problem
    By Whoosh in forum Engine & Drivetrain
    Last Post: 6th December 2007, 12:06
fuelisue
