Thread: Torque settings
    Nov 2010
    Maidstone
    Default Torque settings
    Hi, could someone with a Haynes manual write down the torque ratings for cambelt tensioner, water pump bolts, roller, and the 4 flywheel bolts? Many thanks
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    what engine are we working with rob
    Nov 2010
    Maidstone
    What an idiot, i do apolagise, long day, its a Z19DTH 1.9 cdti 150.
    Also does anyone know much is the total litreage of the coolant system? After doing the belt just need to know how much of neat/water needs to go in and does the bumper have to come off to do a full flush.? Many thanks
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    crank pulley bolts 25nm
    engine mount 55nm
    water pump 26nm (using new bolts)
    cooling system holds 7.5 litres
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    engine mount 55nm
    Nov 2010
    Warrington
    These are for the Astra but should be the same.
    As above and.....
    Timing belt idler bolt 50,
    timing belt tensioner 30,
    (crank pulley bolts) vibration damper 25,
    Aux tensioner bolt 50,
    Aux idler roller 50 - this is attached to the block mounting bracket (as well as the second one next to the AC comp) on the Astra probably the same on the veccie.
  1. Torque Settings
    By lizard in forum Handling & Braking
    Last Post: 21st June 2011, 17:27
  2. torque settings
    By mparks8590 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2011, 14:10
  3. Torque settings
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2011, 21:37
  4. Torque settings ?
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 09:50
  5. Torque settings??
    By Griff72 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2010, 19:42
what is torque setting of vectra flywheel bolts
vectra torque settings
insignia cdti engine torqe settings
vauxhall torque settings on vectra z30dt
vectra z32se water pump torque
vauxhall vectra cdti rocker torque settings
z19dtg water pump bolts
z19dth water pump torque specs
1.9cdti vectra flywheel torque specs
vauxhall 1.9 crank pulley torque
z19dt cambelt torque settings
talk settings vauxhall vectra flywheel 05
