Results 1 to 10 of 14
Thread: name the part
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default name the part
    What the name of the part that the small boost pipes connect into? its white and is located at the front of the engine bay near the passenger side headlight?
    South east
    Probably depends on which engine you mean.
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Boost sensor
    Aug 2011
    Basingstoke
    Trim : SRI
    Its a 1.9cdti 150.
    scotland
    easy .... its the broken bit !!
    Aug 2011
    Basingstoke
    Trim : SRI
    I give up lol
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I think it is a Boost Sensor, it has a pipe that goes down the front of the engine and 2 flexi black pipes that go in under the engine cover which split and you replace with Silicone ones
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Not 100% sure but I think the little valve with the white top is the turbo vacuum sensor (wastegate??) Part Number: 55563532
    In the blue oval at bottom/right of pic
    Hopefully someone can confirm
    Good luck
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Aug 2011
    Basingstoke
    Trim : SRI
    Quote Originally Posted by Damo77 View Post
    Good luck
    Thats the 1 mate...just out of interest does your shake and vibrate? mine does badly and just wanted to make sure that it should or shouldnt?
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Tell you somet Mate u seem to of had a endless lost of problems with ya car since you bought it
  1. part help
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 18:26
  2. Replies: 70
    Last Post: 15th October 2008, 18:51
  3. My busy week part 3 (3rd & final part ;)
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 17:13
