Thread: abs & tc light on
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default abs & tc light on
    after getting 2 new rear hubs fitted do they need reset or what could be wrong
    Oh dear, there are two types, looks like the wrong type is fitted and hence the ABS module is not receiving a signal from the hub
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    normally the ABS should clear when the fault is rectified, you need to get it read by opcom/tech2 to see what its reporting is wrong
    Just had a thought, isn't this the same as when you spin your car on ice
    The Traction Control gets confused so disables itself
    You then need to drive on a solid surface for about 3 miles, switch the car off, then back on again, and all is solved
    Try that
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    i drove 22 mile home in it and still the same , the man is going to read it on Friday
    does this mean 2 different hubs i have been told they are all the same on the rear
    Not there are two types of hubs for all model types
    scotland
    I thought they were same too
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Only one type listed and showing on EPC
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    i will see what the computer say,s on friday and report back
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
