Thread: Signum lowering advice please
    Bournemouth
    Default Signum lowering advice please
    Hi, newbie here....
    Have a v6CDTi Signum, that NEEDS dropping a tad to tighten up the handling and sort the aesthetics out....
    LMF detail the Eibach 'kit' for £575, but I'm not in a poition to spend that much yet, and the car has only done 37k miles so shocks should stick with me for a while right?
    So who does spring kits for a Signum, and how much etc ?
    thanks
    Andy
    Bournemouth
    Ex-Staff Full Member Mark The Cabby's Avatar
    Feb 2006
    In a house
    Vehicle : Ford Mustang
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Hi Andy,
    LMF will also sell the spings without the shocks, I could not find them on the LMF site. I could only find the Vec-C estate LINK but before i fitted my Signum with the Irmscher kit i purchased a spring kit from LMF. I think the price in the link is very close if not the same for Signum's...
    Mark
    It's Mustang time...
    Pm Andy vec as i think he has just changed his springs and his old springs are from a Design so are lower than yours not sure on the weight issue though but i am sure someone will know !!!
    Feb 2006
    In a house
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Quote Originally Posted by drinky
    Nice thinking Chris, But the weight thing is a problem with this idea. The 3.0 Ltr is all alone in the weight area. Do you remember when i tried to sell the Eibach spring i bought, They are not any good for any other engine because of the axel weight...
    SEE you 3ltr diesel boys do like to be different dont you Absolutely agree mark but worth a punt !!!!!
    [Ex]Admin Duncan's Avatar
    Unfortunately Andyvec's springs wouldn't be any use Drinky. The 3.0CDTi has a lot heavier front axle weight due to the lump of an engine it has, a lot heavier than the 1.9CDTi - so it's not going to be advisable to fit those springs.
    Edit: Started to type this reply then the phone rang! - so just seen Cabby's reply as I posted!
    As Cabby said, you can just get spring kits from Eibach or Irmscher even. As yours is an Elite, I would seriously consider replacing the dampers at the same time (may need to wait until you have the cash) as you'll be putting lowering springs on the Elite dampers - so you'll probably end up with a 'double bounce' due to the stiffer springs but still having the longer travel dampers. You'll also wear out your dampers quicker by using lowering springs on those dampers.
    Bournemouth
    Proper prompt response guys thanks!
    good call about the dampers, think I'll be patient and save me pennies...
  1. advice on lowering
    By byers in forum Handling & Braking
    Last Post: 6th December 2011, 12:03
  2. car lowering advice
    By darko2301 in forum Handling & Braking
    Last Post: 3rd June 2009, 00:08
  3. Lowering advice
    By Ziggy in forum Handling & Braking
    Last Post: 15th April 2009, 16:05
  4. Need advice on Lowering
    By bizerk in forum Handling & Braking
    Last Post: 15th September 2008, 18:33
  5. lowering advice please
    By lizard in forum Styling
    Last Post: 29th May 2008, 22:43
