Results 1 to 10 of 11
Thread: Headlight condensation
    Jun 2009
    Chelmsford
    Default Headlight condensation
    Overnight my N/s headlight has gone from clear to full of condensation, thought it would clear itself on a drive to work but still really bad, any solutions to clearing it or is it a new headlight job!!
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    If its just a small bit of water you can get away with using the wifes hair dryer to dry it out. Find out where its coming in first. Since fitting after market HIDs ive had water getting in where the grommet goes through the rear cover, ive used Vaseline to seal the grommet and thats working fine.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Some people also put the little silica gel packets that you get in boxes for electrical goods into the backs of the headlights, downside of this is you need to fish them back out every so often and dry them out on a radiator for a few hours so tie a bit of string to them
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Take the rubber gaiter off the back of the light , and drive home/around with your lights on that way the heat from the engine bay will access the light and dry it out .
    If this does not clear it after a couple of days then you probably have a pool of water in the headlight and this will have to be removed first , when your happy with the light put a couple of those silikane satchet,s inside the light that come with electrical eqpt should keep it dry .
    That along with being more carefull when you fill the windscreen washer bottle,dont worry we all do it and this is the single cause of head light,s filling with condensation .
    and still loving it
    Jun 2009
    Chelmsford
    I work nights so headlights are on all the time have 50k hids fitted, also not topped up washer level for months so i know its not that, just happened one night, on way to work clear on way home full of condensation!!
    Sep 2011
    Sipson
    mine did it after I changed the bulbs a couple of weekends ago, but I also don't have the plastic caps that sit over the back of the dipped bulbs. Trying to find some but having a bit of trouble buying them on their own, was thinking about trying some plastic, ballon or something tied on with a rubber band if I can't find any to buy. Could just be the change in temperature of late.
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    vec headlights have condensated since new, worse with this cold weather.
    Regular Member Bigglesfliesundone's Avatar
    Jun 2011
    Darlaston
    Talking Hairdryer
    I looked up this thread after the Halfrauds chappies failed to put the rubber cup back on my n/s light after fitting a new bulb and the lens was running with condensation!
    Now its fair to say I'm a complete DIY eejit but I thought I'd have a poke so took the cover off, removed the dipped bulb and holder and pointed a Russell Hobbs three speed hairdryer at the back of the light unit.
    It wasn't long before I realised it was going to get dark before I got any result so decided to get the front end of the hairdryer in very close proximity of the plastic lens cover and after about 15 minuter I had a result, the condensation was lessening.
    Just make sure the bulb is out to allow the heated air to escape and apply copious amounts of patience and job done.
    Now feeling very smug and with a clear lens again
    This site is great!
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by krisby View Post
    I've got a damaged zafira headlight in my loft. I'll check and see if the rubbers fit the vec if they do. You can have them
    Feb 2011
    Selby
    Yeah - those rubber covers are critical. When I bought my Vectra the let headlight was full of condensation. Guess what? No cover. Found the cover sitting under the headlight.
    I dried it out by taking out all the bulbs, then pointing a halogen lamp at the front of the headlight to gently heat it for an hour or so. Once it was all clear, I refitted the bulbs and the rubber cover, and it's been condensation free ever since.
  1. Headlight condensation
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 13:25
  2. Condensation in headlight
    By shamus5178 in forum Bodywork & Interior
    Last Post: 13th June 2009, 19:23
  3. Condensation in Headlight
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2008, 15:48
  4. condensation in headlight
    By johnny kebab in forum General Chat
    Last Post: 11th October 2007, 17:10
  5. Condensation in Headlight!
    By Robbie in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 17:11
