Thread: radio working, not working, working again
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default radio working, not working, working again
    the radio was fine on the way to work this am. when i came out of the paper shop tho the sound was terrible, it was all muffled and not really useable.
    so i turned it off and pulled keys out once parked, now it seems to be working again.
    is this a known issue or just " one of those things"?
    thanks
    Full Member
    Mar 2011
    n. ireland
    must be an issue because mine is the same, i have to switch off then on to get reception mine is the cd 30.
    Sep 2011
    Birmingham
    Trim : sri
    oic, i think mine is the cd30 also.
    hhmm wonder what it could be then
    Barrow In Furness, Cumbria
    Mine did this once, then was fine again. CD30 as well.
    Nov 2010
    Lj.si
    OK, i have a lot of this happening with the same radio and the same car. One time per almost every week and sometimes even twice a day:
    In the moment i start the ignition, sometimes the sound of CD30 unit (radio or CD) gets realy wierd. It gets very quiet, or it gets very loud, and always totaly distortioned. So i have to turn off the radio. If i turn it on later, the sound is the same.
    The sound is normal only if i turn off the ingition and then start the engine again.
    Is there any known solution for this problem?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I have not had a CD30 radio in any Vectra that I have driven.
    However a quick suggestion.
    Assuming you can do so, turn off the Ignition logic, so the radio does not come on with the ignition.
    You will have to turn the radio on/off manually.
    There is a outside possibility that starting the engine, and the voltage drop when doing so, is causing the problem.
    Maybe worth a try to see what happens.
    Plus what engines do you guy have?? Petrol or Diesel??
    Edit: searching Tinternet, it seems that some CD30's have overheating problems, and the answer seems to be to have a cold feed to the back of the radio.
  1. Radio on/off button not working
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2012, 15:03
  2. Replies: 0
    Last Post: 10th November 2011, 22:58
  3. Radio code not working!
    By animal22 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 22:00
  4. radio not working
    By neil.r in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 01:27
  5. radio controlls not working
    By neverlandandy in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2010, 17:16
