Thread: Gear change when cold
    Apr 2006
    Kent
    Default Gear change when cold
    Hi Ya peeps,
    Has anyone else noticed that the colder it is the harder it is to change gear for the 1st few mins then after that it's ok?
    Harry you mention on another thread about this? what it yours like?
    Is this normal? or is there a fix? it is going in for the engine mounts soon so if anything needs to be done they can do it then.
    Cheers,
    Martyn.
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    No idea if its normal, but when my 3.0 CDTi is started from cold, going from 1st to 2nd can sometimes be a bit harsh. Only for a few minutes though, after say half a mile of driving it goes and the gearchange is nice and smooth.
    Apr 2006
    Kent
    Hmm seems like it is a trait. Just the warrantee runs out soon and want to get it resolved if there is a fix
    Cheers.
    Regular Member grumpano's Avatar
    North West
    No its not a problem,seems to me all Vecs are the same.Its funny though when i'm towing my caravan the gearchange is lovelly.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Mine isnt too good when cold either, and mines only done 13K!!!!
    Regular Member simac's Avatar
    Wirral
    I'm sure I read somewhere that it's just because the gearbox oil is thick when cold ? mine is the same and when warm is smooth.
    Regular Member steveo's Avatar
    Darlington
    I have a SRI 2.2 direct with 6000 miles on the clock and my gearchange is stiff at first then after a few miles it is realy smooth seems a common thing.
    Northants
    Had a real problem geting 1st gear when cold when I got my 2.0 DTI with 12,000 on the clock. Now it has 40,000 on and the gearchange is no problem. Maybe it's a running in thing?
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Pah, you want to try it first thing in the morning when the temperature is -30 C, Then you will know what a stiff gearbox feels like
    I was very supprised that the 2.0 DTI started at all, took about 25 seconds of cranking though.
    (Poland last winter. Brrrrrr).
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Stiff gear change when cold - fluid changed
    By cont1204 in forum Engine & Drivetrain
    Last Post: 18th December 2012, 14:58
  3. Gear Problems on cold start up's
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 23rd January 2011, 19:23
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. difficult changing gear more so when cold
    By teddy in forum Engine & Drivetrain
    Last Post: 9th November 2009, 14:57
vectra c 3.0 cdti stiff gear selection
