Thread: Manual cranking
    Nov 2010
    Maidstone
    Default Manual cranking
    In the past having only owned petrol engines, to find tdc i used to remove number 1 plug and use a screwdriver or the like down the port, but having now got a diesel and looking at doing the cambelt i shall need to crank it a few times by hand under cyclinder pressure, my question is can the engine be cranked by hand or will glow plugs have to come out? Hope that makes sense. Many thanks
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    you can turn it over y hand with glow plugs still in mate, if thats what you mean? will make it a little easier to remove them, but for the hassle of removing and refitting imo not worth it
    Nov 2010
    Maidstone
    Thats just what i needed to know, many thanks.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If its a cdti 150 there's a bung on the front of the cam cover next to the dipstick.
    Nov 2010
    Maidstone
    Forgive my ignorance but a bung for what?
    East Midlands
    To turn the engine over to find TDC, after you remove the cam cover replace the wheel using a couple of bolts and turn the wheel easy peasy lemon squeezy ,no need for GP removal.
    Nov 2010
    Warrington
    The bung is probably the exhaust cam timing tool screw. You can remove the screw cap with an allen key. The timing peg (part of the timing tool set), which is spring loaded screws into this. When the crank bolt is turned and the cam rotates, the tool engages with a recess in the exhaust cam shaft at TDC.
    bb
  1. 120 cdti cold start cranking
    By Slammedorion in forum Engine & Drivetrain
    Last Post: 18th January 2013, 13:15
  2. Vectra c 1.9cdti (dead not turning/cranking)
    By Jaybee-le2 in forum Engine & Drivetrain
    Last Post: 14th April 2011, 18:34
  3. manual
    By kevchall in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 16:01
  4. Doesn't it tell you this in the manual?
    By mucklestone in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2008, 20:02
  5. Vectra SRI 150 Manual and CD70 Manual?
    By rscosworth in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2005, 22:30
manual cranking
