Thread: Z19dth cambelt change!!
    Nov 2010
    Maidstone
    Default Z19dth cambelt change!!
    Just contemplating doing the cambelt/water pump myself, i hope its within my ability but having watched a vids and reading some how 2's i couldnt see anyone using any sort of locking tools, are they really needed or can you just crank it round till markers line up for tcd, release tensioner and refit all and just make sure no markers have moved. Only reason i ask is as im having a go myself im trying to save some cash and to buy these locking kits its about £90, any help would be greatly appreciated.
    Engine : 1.9 CDTi
    Aslong as you align everything and mark everything you dont need any locking tools.
    Nov 2010
    Maidstone
    Just a silly question but how much are these cams/crank likely to move unless you put a socket on there and deliberatly move it a notch or 2?
    Also the only thing that bothers me slightly is getting the right tension on the belt, how will i know when its taught enough?
    Nov 2010
    Warrington
    Sealey do two versions of the locking tools - one manufactured in China (about £45) and the other German made (approx £100). I found the tolerances on the Chinese version OK. The crank tool could have done with oil pump peg being made better, but it still fitted with no movement for me.
    I found that the timing belt tensioner bolts into a 'floating' nut on the block. So when you come to tension it (the timing belt tensioner,) the nut slides in its groove rather than the spring assembly rotation the tensioner cog/wheel back. (It's not easy to put into words but very obvious once off the car).
    The best tip I can give - mark the existing (the one on the car now) tensioner and block so that if you remove the tensioner, you can then re-align it with said mark, as if you were to re-use it. Take the old tensioner and new one, hold them up to each other (back to back) and transpose the mark onto the new tensioner (they should be identical - check they are before removing the old one).
    Get the locking kit - it's very easy with it and will help boost you confidence. I'll see if I can find a link to the version I bough later.
    Your should be able to twist the belt about 45 degrees when adjusted properly, although, I've not heard were in the loop you should do this e.g between the cams or between the HP pump cam and water pump.
    bb
    Regular Member goosey_1976's Avatar
    Nov 2009
    Dunston, Gateshead
    Vehicle : Insignia 2.0 SRi Nav
    Trim : SRI
    Engine : Diesel
    Year : 2010
    Mileage : 65k
    I had a go at mine at 72,000 miles as I was reading on here about all the failures and the fact Vauxhall recommend 100,000 miles.. I actually couldn't see the water pump lasting that long, but found to my horror they had been replaced prior to me buying the car.. I am a fitter by trade but diesel engines ain't my area, but thought i'd have a go anyway.
    When you strip it down and get to the belt, align the marks on the crank pulley and the casing and if I remember the camshaft mark should be at about 2 o'clock. This is the pulley nearest the front of the engine.. The second pulley is the high pressure fuel pump. I marked all three of these these with a tippex pen, and then loosened the tensioner off and removed the belt. In the kit I bought I had a replacement tensioner and guide pulley which I also changed.. Then after replacing the tensioner and belt I tensioned the belt. This was achieved by matching up a small "spike" to a groove in the tensioner mounting and then nipping the nut up as it slide inside the casting. Then I used a socket and bar to manually turn the engine and check the movement of the tensioner. This was also to test interference between pistons and valves incase anything had moved.. Then I cracked on and put it all back together. Fired it up and yeeehaa.. I didnt bend owt!!
    P.S. I did change the water pump too.. Cost 80 quid for the cam kit and 35 quid for water pump
    Apr 2011
    bristol
    I did my belt yesterday with no special tools,there is timing marks for the camshaft on the pulley and and on the casing,however the mark on the crank pulley does not line up to the mark on the casing,
    When you buy a belt from say vaux or gates they have the marks on the belt that will line up with the marks on both pulleys so it makes it very easy, the pump pulley does not need to be lined to anything,you can not go wrong.
    My car is a 120dth but the set ups are both the same
    East Ayrshire
    Trim : SRI XP1
    As above I've done mine a couple of weeks back. Had to get a T50 or T55 torx socket aswell as other ones, think it was E18. I done mine in a few hours, took my time and made several marks to ensure it was spot on. It was much was much easier than I thought It'd be. There's a really good how to on here. I followed TIS aswell and all been good so far. I felt as though the car was pulling better and idling smoother. Mine had done 54k and had a split in it so got it in the nick of time
  1. Z19DTH cambelt setting warning
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 25th April 2017, 03:13
  2. CDTI 150 Z19DTH Inlet Manifold change - Prices?
    Last Post: 19th January 2013, 12:20
  3. z19dth broken cambelt
    By RyanNI in forum Engine & Drivetrain
    Last Post: 11th April 2012, 19:45
  4. How long to change a Z19DTH
    By aidy-cdti in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 08:29
  5. Cambelt change
    By Andy in forum Engine & Drivetrain
    Last Post: 4th July 2005, 23:23
using special tool timing belt z19dth
locking tool z19dth
z19dth cambelt change
