Results 1 to 10 of 11
Thread: quick ABS question ?
    scotland
    Default quick ABS question ?
    code on OP-COM reads c0040-06 front right speed sensor circuit open or low voltage , does the ABS on all other corners still work or is it all defective till this is fixed ?
    pretty sure its the 2 pin connector on the harness under the arch as its corroded so until I can source ne wiring whats the score with it ??
    cheers
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    it will turn off all theabs mate
    can you disconnect and clean the connector with some wd40?
    do you get a reading on multi meter when turning the wheel?
    scotland
    tried that mate but not sure if I done it correctly , reading was o ohms and still same wen I turned hub ?
    not sure if my ancient MMR is up to it ?
    will try jump the wires first before a new hub .
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    it could be that the sensor is duff or incorrectly gapped if still reads 0.
    scotland
    Quote Originally Posted by CritchvxD View Post
    cant be incorrectly gapped tho as its in the hub and communicates with th driveshaft , an thats all tight .
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    do you get a voltage if you turn the hub?
    scotland
    no , no change but I have done this on a hub that is ok so might be my meter too , will jump / bypass the connector tomoro an let you know the outcome .
    cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds pretty much the same as what happened to mine. The wire that runs between the chassi leg and hub has a round 2 pin female connector and the connector corrodes away. The wire isn't much from VX
    Regular Member billpayer's Avatar
    Oct 2009
    essex
    Glad I found this thread, saves me making another
    I have just failed mot with intermitant abs fault, the abs and tc lights are on pretty much all the time but sometimes go of for a few days at a time. I had a guy look at it and he pulled a few conectors apart sprayed them with wd40 wich didnt do anything. He said that the wire comes in three parts and wants to change 2 of them and that this might fix it if not it would be a new hub.
    When he read the fault he had a snap-on fault reader and it said there was an 'open circuit nsf'.
    so my questions are,
    1. is he right to suggest this couse of action?
    2. is it possible for me to try and clean the sensor in the hub?
    thanks
    bill
    Oct 2009
    essex
    I have just failed mot with intermitant abs fault (Signum 2.2d), the abs and tc lights are on pretty much all the time but sometimes go of for a few days at a time. I had a guy look at it and he pulled a few conectors apart sprayed them with wd40 wich didnt do anything. He said that the wire comes in three parts and wants to change 2 of them and that this might fix it if not it would be a new hub.
    thanks
    bill
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
