Thread: Handbrake travel.
    Aug 2010
    Leeds
    Default Handbrake travel.
    Noticed when pulling handbrake up and down a few times with foot off the brake pedal sometimes it comes right up unless i pump the brake pedal then it adjusts to correct limit, is this normal?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    mines different mine travels all the way up when i apply the foot brake
    Aug 2010
    Leeds
    Weird checked it again and it's still the same, ok though as it holds fine brake pads are 50% worn so next year it will have a new set which should make the travel much less.
    You should always be applying the handbrake once the footbrake has been applied, and this keeps it adjusted
    Pulling the handbrake up it should not click more than 3 times, if it does then adjust the handbrake using the above method (as described in the handbook)
  1. Travel Assistant
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2012, 20:28
  2. Handbrake Travel
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2012, 23:26
  3. Travel Cot
    By simonturner1975 in forum The 'Off Topic' room
    Last Post: 22nd July 2009, 12:43
  4. How Far Would You Travel....
    By BigMan in forum General Chat
    Last Post: 9th May 2008, 17:01
  5. PVS Travel
    By Telboy in forum General Chat
    Last Post: 4th June 2006, 21:58
