Thread: 1.9cdti 120 glow plug replacement.
    May 2008
    newcastle
    Default 1.9cdti 120 glow plug replacement.
    Hi all, just wondering has anyone managed to change thier glow plugs on a 1.9cdti 120. & if so how ?. i've had a bash but it seems imposible to get any kind of socket anywhere neer then due to pipework that runs above it, even getting the connectors off is a complete sod of a job. changing the thermostat was bad enough but i managed where this just seems imposible to do.
    Any advise would be greatly appreciated.
    Cheers.
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Quote Originally Posted by john1 View Post
    Cheers.
    Bump
    i would love to see a how to
    Apr 2009
    Bournemouth
    Hi,
    could someone please look through a haynes manual to see how they get them out.
    1.9DT
    thank in advance
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Haynes id a bit useless it says "On z19DT engines, undo the two retaining bolts, disconnect the four vacuum hoses and remove the vacuum pipe assembly from the top of the canshaft cover"
    I would also remove the egr for better access to two of them.
    I know they can be a pig to remove and have a tendancy to snap and leave bits still stuck in the engine.
    I gave up trying to do it on my 1.9 (120) and got the garage to do it for £60 labour. Bought the plugs from VX for £40.
  1. 1.9cdti 150 16v engine glow plug size...
    By dogmorfmucion in forum Engine & Drivetrain
    Last Post: 18th November 2011, 09:06
  2. Glow plug replacement
    By lee gsi in forum Engine & Drivetrain
    Last Post: 26th November 2010, 22:11
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  4. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
  5. Glow plug replacement
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2008, 10:23
vauxhall 1.9 cdti glow plug replacement
