Thread: Where's The Dimmer Control Wire ?
    Inverness
    Default Where's The Dimmer Control Wire ?
    I've just removed my CD 30 and fitted a Pioneer head unit. The Pioneer has an orange 'Dimmer Control' wire which I want to connect up, but I don't see where to connect to on the car's wiring loom.
    My car is a new ( 56 reg ) 1.9CDTi. I previously had a ( 53 reg ) 2.2SRi which had an illumination wire running into the factory fitted stereo, so there was no problems there - the new one has me stumped though.
    I've pulled out the heater controls to try and I.D. the culprit when I switch the lights on, but it's just a mass of small wiring which I cannot access without cutting into, which I don't really want to do !
    I've also pulled the lighting control on the other side of the steering wheel out but it's just the same - small wires which I cannot get a voltmeter near.
    Any suggestions ?
    I'm no expert on the ICE side of things, but I think it's due to your 56 model now being full CANBUS. The stereo is now totally CANBUS (I believe) and that will probably explain the absence of wires like that.
    I'm sure one of the ICE experts will be along to confirm that or say what a load of trollox I'm talking!
    Feb 2006
    Dorset
    Right you should be able to take it off the ciggy lighter socket ,
    to do this
    remove the gear stick surround
    then take the the fag ash bit out of the ash tray
    then unclip the surround and lid
    You should then see the illumination wire for the cig lighter if fitted taped to the power loom for the socket
    Feb 2006
    Dorset
    just looked at my last pic and there it is , grey wire with yellow trace .
    Feb 2006
    Dorset
    no your not mate , one of the last places for an ignition source and illumination in the vectra is the fag lighter pretty much all the dash is done with surface mount diodes and canbus , bluddy technology ......
    Inverness
    Default Thanks !
    Thanks for the pointers guys, will try this at the weekend.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    How do you pull the ashtray-surround out?
    i've just popped my fingers down inside the aperture and pulled it back up..
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I tried that before but was afraid to break it - will give it another try now that I've seen the picture
    Feb 2006
    Dorset
    yep just pull it up , its clipped in
  1. One dipped beam dimmer than the other...
    By y2joeyb in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 15:45
  2. Bulb gone on the dimmer thingy
    By Sean-2.2Direct in forum Bodywork & Interior
    Last Post: 24th August 2009, 23:08
  3. Anybody Know Were The Dimmer Control Wire is ?
    By tonywolst07 in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2007, 12:34
  4. Headlight/Fog light/Dimmer Cluster....
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2007, 08:23
  5. Dimmer Control wire again
    By Ian S100 in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2007, 09:11
