Thread: 2.0 DTi Oil change through dipstick
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Default 2.0 DTi Oil change through dipstick
    Folk, just wanted your thoughts on performing an oil change through the dipstick with the aid of syphon pump. My matey who works for VX used a syphon last time, less mess, nice and easy. But is it worth dropping the oil out the sump this time round ????
    Thanks in advance.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    drain sump everytime bud,using a syphon doesn't get all the old oil out,leaving dirty oil in sump is the last thing you want,do it right it's not a long job.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Cant see how you wouldnt get as much out with a syphon as you would through the sump hole tbh. From what ive seen of them you can turn the hose around to reach most parts of the sump.
    Admin plasma's Avatar
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    as above, tried it on 2.2dti's and 1.9cdti's... 99% removed, if there is any crud it would block up the intake of the syphon which is hasnt done once yet.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Slough
    76 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by plasma View Post
    the mecanic that does my car does this with the cars he srvices . but not with mine as i need to get him a new sump washer each time . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Id like to try one of these syphon pumps tbh. VX, in their wisdom, decided to put the sump plug at the front on the z18xe for some reason which means I cant get all the oil out when I do mine on small ramps or axle stands!!
    Jul 2009
    Brighton
    If the main dealers are all using them, then it can.t be that bad!
    I'd also give it a try, saves getting under the car, taking the engine guard off etc. Plus it stores the oil in a sealed container ready for disposal!
    Anyone used one and had problems?
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    I have a cunning plan. What if I park the car on a slight incline, so the oil is at the front of the sump. Would this enable me to suck out most of the oil ????
    If you are using a dealership, check the receipt for the replacement seal and plug
    Equally, I always sit and watch them doing the work
  1. Dipstick
    By bigmac in forum Insignia car chat
    Last Post: 2nd July 2012, 21:38
  2. Oil Dipstick Help
    By Yohan in forum Engine & Drivetrain
    Last Post: 7th April 2012, 22:04
  3. dipstick snapped!
    By adammarc in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2011, 22:43
  4. Marks on dipstick
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 20:08
  5. dipstick oil change
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 17:25
change oil vectra 1.9cdti syphon
