Thread: Change alternator on Z22YH
    Jun 2006
    Kirkintilloch, Scotland
    Default Change alternator on Z22YH
    Car is a 2004 elite estate with Z22YH engine.
    Going to replace my alternator and have some questions please with regard to the instructions in my Haynes manual.
    1) It states that I should drain the cooling system. Presumably I only need remove sufficient to take the level below the top hose – a pint?
    2) It states to remove the wheel arch inner cover. Is this straightforward or should I expect to encounter rust crumbling bolt heads and is it obvious which bolts need to be removed.
    3) Any further advice.
    Thanks,
    Dave
    South east
    Draining the coolant is only needed so that you can move the hose out of the way, if you can find a better way than draining all the coolant out, so much the better.
    Taking the wheel arch liner off is easy once you figure out the plastic rivets - push the middle pin inwards and it'll fall onto the ground, then you can pull the rivet out. the middle pin stops the rivet coming out. Find all the pins off the floor so you can reuse them. I don't think taking the liner off helps you do the job much though.
    Jun 2006
    Thanks.
    I note elsewhere a suggestion to consider replacing the belt and tensioner whilst replacing the alternator. Note car has done 68,000 miles.
    Dave
    South east
    There's a How2 for the belt/tensioner for the 2.0T engine, which is very similar or same setup as the 2.2
    http://www.vectra-c.com/forum/showthread.php?t=142441
    Jun 2006
    Thanks. I had seen the How2 but was unaware that the set up was the same as mine.
    One thing I failed to mention was that my car is an automatic. Will there be sufficient space for me to extract the alternator without removing additional coolant pipes?
    Dave
  1. Replies: 1
    Last Post: 3rd January 2013, 18:36
  2. z22yh alternator
    By elite lee in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2012, 22:11
  3. vec c 1.8 alternator change
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 13:20
  4. alternator change
    By glasgowrob in forum Engine & Drivetrain
    Last Post: 1st January 2010, 12:58
z22yh alternator replace
z22yh fan belt removal
remove alternator vectra site:www.vectra-c.com
z22yh drive belt replace how to
Z22yh alternator belt replace
vauxhall vectra alternator removal site:www.vectra-c.com
z22yh belt change
opel vectra c 2.2 alternator how to change
vectra c alternator removal
vectra c 2004 1.8 alternator how to remove
z22yh alternator removal
z22yh alternator problem
how to change z22yh engine
