Results 1 to 10 of 21
Thread: unknown valve
    Feb 2011
    lisburn
    Default unknown valve
    Hi my 3.0cdti y30dt had a small green plastic valve connected between what I think is a solenoid and the main engine I have a picture in the link. The problem is when replacing the pipe it broke so the pipe was fitted without it. The car goes fine until you give it the welly then the spanner comes on and limp mode. When I disconnect the pipe I hear like a vac release and upon restarting the spanner has gone. Can anybody tell me what this green valve is and a part number for a replacement?
    Regards and thanks,Ian.
    http://s1220.photobucket.com/albums/...ccyvalve-1.jpg
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Might be the boost sensor
    Feb 2011
    lisburn
    Thanks for the reply Paul, I cleaned the boost sensor it is under the engine cover to the back .at the time it was well gunked up. This is different
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Just had a look at mine with the aid of a torch. Reluctant to remove it to see what's inside in case it breaks like yours did .
    Looks to me like a one way/non return type of thingy. With it off, can you blow down each end or just one way?
    Feb 2011
    lisburn
    Hi,thanks for the reply. Mine you could blow through both ways but it may be damaged.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    I think your best bet at this stage might be a trip to a VX parts dept and have a look at their microfiche. Get the part identified, get a price and then walk away and have a think what your next move will be.
    Might be worth just taking the old part in and seeing what they say. I can't imagine it was designed to flow both ways as what would be the point of a bit of plastic? As you've found out, the engine doesn't like it not being installed so it must serve a purpose.
    Keep us posted
    Feb 2011
    lisburn
    Hi, did that already my local vx dealer could not find it on their system lol
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it not a 1 way valve for the turbo actuator?
    Thing is with vx parts only as good as bloke behind desk plenty of times I've had people say can't find it we don't sell it separately etc etc. only to go to a different dealer an have another bloke find excactly what I'm looking for
    Feb 2011
    lisburn
    Hi tried 2 different dealers even had car with me and showed them where it goes but to no avail I thinlk its the 3.0 izuzu engine stumps them.
    Sodding Typical on Sea
    Its a small non return valve on some kind of vacuum line to prevent the diaphragm reversing on itself under certain conditions (so am guessing) but think it will be boost or overboost sensing?
  1. unknown fault code
    By Dannyboyjosh in forum Vectra C / Signum Troubleshooting
    Last Post: 27th April 2012, 22:12
  2. unknown error
    By khile in forum Engine & Drivetrain
    Last Post: 15th March 2010, 14:41
  3. unknown fault
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 14th August 2009, 21:30
  4. Unknown fault????
    By bigpaw35 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 19:35
  5. Unknown connector plug?
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2007, 21:15
