Thread: Clutch peddle switch
    Aug 2010
    London
    Default Clutch peddle switch
    HI there
    I have a slight problem. I have a 2003 1.8 vectra c LS and my cruse control switch (Clutch switch) keeps disengaging. To enable itr i need to pull the clutch peddle fully up with my foot but any bump or random times it switches off.
    I know the spring on the clutch peddle probably needs adjusting, but how???
    Any Ideas please
    Glasgow
    It needs replaced as it weakens or breaks over time. Cant be adjusted mate.
    Full Member spennny's Avatar
    Blantyre
    What he said above mate,
    Its easier as i found out to snap the old one out and put the new one back in, should take a few mins
    Aug 2010
    London
    aa dam
    is it costly and can i do it myself??
    it just a case of changing the spring would it not be?
    Blantyre
    Think it cost me about £10, get the spring mod also, might help thats not expensive either, and yes you can do it yourself
    Aug 2010
    London
    a cool cool
    can you buy the kit on ebay or did you get it from a dealer?
    Blantyre
    Go to the dealer mate, just as cheap and you will get the right parts
    Aug 2010
    London
    is their any diagrams, pictures of how to do this.
    I found a how 2 guide and took a look but can not find the holes that it refers to. only the current sprint which is located inside a black covert which is connected to a long black plastic rod that locks into the back of the peddle.
    I probably being silly but is this actualy easy to do as i it look as a little more complicated that it sounds.
  1. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  2. Where is the switch on the clutch pedal?
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 19:52
  3. Clutch Switch wiring?
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 13:45
  4. Where is the clutch switch?
    Last Post: 14th December 2010, 10:14
