Results 1 to 3 of 3
Thread: Change Gearbox Oil on 1.8 ZX18xer
    Jan 2008
    Waltham Cross
    Default Change Gearbox Oil on 1.8 ZX18xer
    Hi, I have a 57 plate, 1.8 petrol Vectra with 1st and 2nd gears whining badly.
    So I thought I would change the gearbox oil and add molyslip.
    I looked at the two How Too's but they relate to the Diesal version and the area where the fill plug is (in the How Too) does not look anything like
    mine.
    Can anyone shed some light on this please to enable me to change the oil
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    There are no dedicated oil holes for adding or removing oil on the F17 gearbox, who's idea was that!!!! To remove the oil need to remove the gearbox end plate and let it drain out there. You may need to buy a new gasket for it though. To add new oil im sure someone mentioned you can remove the reverse selector switch and add it in there.
    Jan 2008
    Waltham Cross
    Thanks for the prompt reply, I think it best I find a local gearbox specialist
    and let them have a look. Cheers
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
  3. Gearbox Oil Change
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2009, 23:16
vauxhall vectra c 1.8 gearbox oil change
how to change f17 gearbox oil
how to change gear box oil in vauxhall vectra c 1.8 53
f17 gearbox oil change
f17 gearbox oil fill
vauxhall vectra 1.8 gear box oil
