Results 1 to 10 of 16
Thread: Headlight levelling.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Headlight levelling.
    I know Ginge has already got a thread going about the auto headlight levelling not working but does anyone know if you can deactivate the system. Mine stopped working over a year ago but the headlights have been adjusted to the correct height. Just wanna get rid of the warning symbol because as from next year the car will fail the MOT due to a warning light being displayed on the dash. Cheers people.
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by Hyperhart View Post
    the only way is to repair the problem
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by husky View Post
    That's a bit difficult when Vauxhall have told me there's nothing they can do.
    Glasgow
    There full of poop. When you lowered it did you remove the level sensors from the brackets?? If the answer is no then one of them has probably been damaged due to the amount of movement or force thats been placed on it.
    Get it back on tech2 to see what the readings are, if one of them is way out then it needs replaced and then calibrate the sensors to where your car is sitting just now. Although they will need to follow instructions on the VX TIS system to do this may be to much for them lol.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by byebyeitsagsi View Post
    As this threads been bought up again that's exactly what I didn't do only for the fact I didn't know about the sensors. Will be at some point in the near future booking it in to Vauxhall to fit a new sensor on the rear as when changing the springs we did give the lower arm a bit of a hammering.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Dave, sort out a meet at yours or something and we'll get to the bottom of it.. I'll bring mine off the show car so we can get yours working, and then you can just replace what we used.... come to think of it come down to paddys.. Oxford, on the 25th... Can make yours first job of the day until its resolved..
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    ooooh oooh, i need to fit some level sensors as part of xenon retrofit.. i was wondering where the sensors are supposed to be mounted...
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    yep, no probs, did the AFL retrofit inc. level sensors the other week
    Jul 2010
    Warrington / Liverpool
    Hi guys, I have got that warning light for the levelling on my dash since doing some work on my front suspension.
    I've checked the fuse and the sensors seem to be intact but I noticed I only seem to have the sensors on one side... is this normal or am I missing something.
    Cant see why the light would have suddenly come on now when they have worked for the past 18months I've had the car but thought it a bit od the sensor was only on the nearside?
    Any ideas?
    There are only two sensors, one up front and one to the rear. The fault light will give a fault code to find out where the problem lies.
  1. Auto levelling headlight sensor
    By braby in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2010, 05:00
  2. Self Levelling Headlight problem?
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 20:22
  3. xenon headlight levelling has failed from safe/park position
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2010, 17:31
  4. AFL headlight issue - levelling
    By tox in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 14:45
opel vectra c headlight leveling sensor fail
opel vectra c headlight leveling sensor www.vectra-c.com
