Thread: Rear discs and pads, any pointers.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Rear discs and pads, any pointers.
    Hi all and it's good to be back.
    Sorry if i've put this in the wrong section.
    Today i bought my new discs and pads for the GSi but i'm looking at doing the job myself, i'm a complete novice when it comes to this kinda thing so any pointers would be greatfully received. I know i need a piston rewind tool but i bought one of them too.
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    did mine yesterday albeit on a 2.0 dti, fairly easy job, rear disks on mine had never been off before so bolts at back were a bit of a ***** but apart from that went well.
    possibly spray calipers and centre of discs whilst there off.
    and remember to take and leave handbrake off whilst doing it. and when all back together pump brake pedal back up before reapplying handbrake.
    11 Post(s)
    Quote Originally Posted by Hyperhart View Post
    any pointers would be greatfully received..
    Plenty of advice in the how2
    http://www.vectra-c.com/forum/showthread.php?t=15092
    http://www.vectra-c.com/forum/showthread.php?t=94063
    EDIT where's the pics gone from the 1st link?
    Regular Member lewcdti's Avatar
    Oct 2010
    South Wales
    +1 use the how2 on here - did mine following it, not too bad a job, the gnarly bits for me were getting the spring clip out/back in as the previous owner had painted the calipers without taking them out first!!!, doing the piston rewind without the proper tool - had to use a long nose pliers - this will work but I recommend a rewind tool if you can get your hands on one, it'll save you time and a sore hand!!, and the bolts which hold the caliper carrier onto the hub are MEGA tight (loctited) so take some getting off - easier on a lift so you could get the clearance underneath to use a nice long breaker bar.....HTH..
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    you could have borrowed my wind back tool, female socket and breaker bar as I have all the kit to do this (did it myself in the spring) would suggest a hearty meal before as getting the bolts out will have you grunting for a good while or the use of an impact gun (i dont have one of them) I was sweating like a geordie on a spelling test when I finally got the last one out (no offence to geordies that can read lol)
    Sep 2011
    Swindon
    Make sure your new rewind tool has the plate with two lugs on it to twist the piston back in rather than just pushing on it.
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    I thought about doing mine myself but figured I'd save myself the effort of locating the rewind tool and paid a garage to do it, lazy ****** I am :-)
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by mickydoos View Post
    In the end i did the same thing.
    I got the caliper off but then the rewind tool i bought was a little wrong, the pins were about 2mm out so i put it back together and took it down the road to the local garage.
    Regular Member travec19's Avatar
    Jul 2010
    Vehicle : Insignia
    Year : 2010
    I found grinding an old socket down leaving two lugs either side worked well getting the piston back, just completed mine on the weekend only to nick the dust boot leaving me with another problem.........any easy suggestions to replace the dust boot?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get a new dust cover an fit it
  1. Rear discs and pads!?!?!?
    By Basher1 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2012, 17:36
  2. how much for rear discs and pads??
    By delberto in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 12:08
  3. Rear discs and pads
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2010, 22:57
  4. Rear Discs & Pads
    Last Post: 16th December 2008, 17:46
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
