Results 1 to 10 of 11
Thread: track rod removal
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default track rod removal
    anybody know how to replace the track rod on a vec c z19dth?
    cheers
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    You on about the outer one. Or the inner one attached to the rack its self?
    Outer ones are about half hour job. Inners will be more of a pain. An you'll need a big f type or similar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    yes inner one m8
    is it subframe off?
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    No should be to it. But obviously will bea bit tight for movement.
    There's tools available on eBay or wteva. That might make it easier.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    cheers pal
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    No worries mate.
    From what I believe job to be.
    Remove front wheels. Pop of track rod ball joint. Remove steering gaiter and should reveal a big nut. Undo that and should come off.
    Try and count / measure threads so that wheel alignment adjustments will only be slight
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    wil have to be tracked anyway as the track rod snapped after a bump
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Have you checked wishbone, sun frame etc. as must of been some bump to snap it :-S
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    sub frame been replaced, wish bones appear to be okay
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Fair enough. Defiantly worth having a full geometry check once it's sorted
  1. track rod ?
    By peadar in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2012, 22:44
  2. Been to a track day
    By bandrew in forum General Chat
    Last Post: 27th May 2010, 15:32
  3. Track Day.
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 18:20
  4. inner track rod removal
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 21:42
  5. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
