Thread: Subframe corrosion holes
    Oct 2007
    london
    Default Subframe corrosion holes
    Took my front bumper off at the weekend to check a suspected leeking intercooler on my 2004 120cdti and was horrified to see some rust holes in the front crossbeam of the subframe where the bumper and undertray had trapped water and crud against it. Anyone else had this problem? I've got a MIG welder so I could patch it up OK but unsure about how to protect all the ECUs and sensors on a modernish car. Anyone got experience of this?
    Jul 2010
    stourbridge
    You've got me worried now, must now check mine next chance I get!
    Hope I don't have to drag my old mig welder out, was regularly used on my previous string of old bangers. Didn't find it very enjoyable.
    You raised an interesting point about the protection of the ECU and sensors, perhaps they should be disconnected before welding? Don't know what the pro's do.
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    That's reason my under tray is in my shed lol
    You can buy circuit protectors for when your welding. Not sure how much they are tho.
    May 2011
    bispham, blackpool
    correct me if im wrong but once you have taken the battery off the ecu etc should be safe as they will not have power going in to them and they will not be earthed so it all should be fine
    also might have to have a look at mine as well as mine is same age 2004 and i live at the seaside all that salt in the air
  1. alloy corrosion
    By zsnotdead in forum Insignia Chat (READ ONLY)
    Last Post: 30th December 2012, 18:21
  2. Vxr centre caps corrosion
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 19:56
  3. Brake line corrosion
    By barry087 in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2010, 21:31
  4. Anti Corrosion Warranty
    By rorycarz in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2007, 20:28
  5. headlight corrosion
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2006, 15:05
is it worth welding my vectra c front subframe
