Results 1 to 10 of 14
Thread: 2.2 SRI rear box outer skin
    South East
    Default 2.2 SRI rear box outer skin
    Lost my lower outer skin on the rear box.
    It has left the inner one which looks like new, in-fact you would not notice the outer one has gone
    Question: Should I paint this inner one to make it last and if so what cheap black paint can I use?
    thankyou
    give it all the help it can get...use either hammerite or smoothrite to help it last... and start saving for the inevetable replacement..
    South East
    can hammerite take the heat?
    That far back there is no real heat to talk of..
    hammerite will take up to 250 deg C.. so manifolds are out, but that far back it's not an issue..the 'can' will not even get to 100 deg..
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Quote Originally Posted by vectrasri03
    Should do, I use it on my brake calipers and trust me, they get HOT!
    daemon turns off the A45 mate?.....
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Painting may not do a whole lot of good as contrary to popular belief, they rot from the inside out.
    Dec 2005
    Quote Originally Posted by Gsi3.2
    Yup 90 degree bends at *ahem*mph in 5th gear do tend to get your calipers a bit warm not to mention the seat of your pants
    Quote Originally Posted by ross_DTi_2.2
    indeed they do, and the water in the exhaust gases condenses between the two skins, rotting out the outer one 1st..
    a little paint never hurts.. but it won't help it forever..
    You are as always 100% correct mate. Very knowledgeable reply.
  1. Rear, Outer Bushes, is this the right kit ? (Powerflex)
    By slot in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2012, 23:55
  2. rear box outter skin
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2011, 11:39
  3. Quicky! Rear pads, is it the inner or outer with spring?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 11:23
  4. Pair of rear outer headrests...
    By danBoy in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 31st December 2008, 22:23
  5. Exhaust rear box outer skin rusty
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2006, 07:51
