Thread: 2003 vectra c 1.8 ls Timing Belt
    Aug 2010
    London
    Default 2003 vectra c 1.8 ls Timing Belt
    Hi There
    I have a 2003 Vectra c 1.8 LS and i was wondering what the recommended timing belt renewal is for them. My car as just reached 64000 and i can not find any history of it being changed. I know the timing belt usually get changed at 60 on most cars. I checked the belt and from what i can see it looks in relatively good state (that's without taking it off).
    Does the belt for my car get changed every 40000???
    Any advice guys would be good.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    60k or every 6 years for the z18xe. I changed mine at 6 years and 44k.
    Aug 2010
    London
    thanks for your reply Das
    I'm presuming 60k means ever 40000 miles? So my car probably would not need changed till I reach 80 000 miles then?? (provided it was changed at 60k-40000 miles) which i have no idea if it was or wasn't other than it looks in good nick from the top cover.
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    As long as it was done it should be ok. Id contact the last owner and check if they defiantly had the belt done, as if it hasn't and it breaks............ did you notice what the tensioner looked like? Original ones are of all metal construction, sure the new ones are made of plastic for some reason. I posted about this when I did mine, ill see if I can find the post.
  1. 2003 Vectra C 1.8 Petrol Timing Belt Noise
    By chrisjt31 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:21
  2. 2003 vectra c 1.8 ls Timing Belt/water pump
    By Tank988 in forum Engine & Drivetrain
    Last Post: 19th January 2012, 18:42
  3. vectra timing belt help please
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 9th July 2011, 13:21
  4. 2003 vectra c ls 1.8 Timing Belt
    By Tank988 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2011, 00:58
  5. 2003 vectra c ls 1.8 Timing Belt
    Last Post: 17th March 2011, 15:59
how long is vauxhall vectra c 1.8 LS timing belt
vectra 1.8ls timing belt
