Results 1 to 2 of 2
Thread: P0380 Error where are the plugs on the 1.9 120
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    StatsVehicle Info
    Default P0380 Error where are the plugs on the 1.9 120
    As title says also what ohms should they be when i put a meter across them
    car starts and runs fine.
    thanks
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    StatsVehicle Info
    the restance of a the glow plug is very low, less than 1ohm if there all roughly the same but below 1 they should be fine m8. if you have an ammeter tes each plug and after initial surge they should draw approx 12 amps
  1. Help error code P0380
    By tomo610 in forum Troubleshooting
    Last Post: 30th June 2012, 20:57
  2. FAULT CODE HELP: p0380-08 glow device general error
    By merikiito in forum Engine & Drivetrain
    Last Post: 19th November 2011, 17:28
  3. P0380
    By ijk571 in forum Engine & Drivetrain
    Last Post: 5th September 2011, 17:47
  4. Glow plug general error p0380-08
    By keith_johnson1967 in forum Engine & Drivetrain
    Last Post: 27th June 2010, 19:16
