Results 1 to 10 of 11
Thread: Rear Brakes Advice?
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Default Rear Brakes Advice?
    Hi guys i need to change my rear pads, ive got a new set from my local stealers, are they difficult to change? and are they the same rear brake set-up as the vec B?
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    no , they're not..totally different
    you must get a windback tool to compress the piston back, DO NOT use anything else or you will need a new caliper if you try to just push the piston back in..
    if the 'how-2' isn't clear enough, post up and we'll try to help you out,
    S.Wales, Nr Swansea
    Thank you very much guys, and special thanks to u GSI3.2 you have helped me out quite a few times now
    not a problem mate, it's what we're all here for isn't it??
    Nicking Ya Dinner.
    Has anyone any idea who sells the tool that actually fits the caliper, or is it a Vx and a need to know thing, I'm really getting sick to the teeth of Vx right now, 3 motor factors and 2 high st sellers and this elusive tool is still not readily available, one offered to order it at £27, but I've not been back to him yet cos I know he's gonna order me a laser one that dont fit.
    VV, Snap-on do a set that includes the correct fitting one..either that or send me down your 'laser' one and i'll move the pins over for you to suit....can't say fairer than that..
    Nicking Ya Dinner.
    Thx Mark, that's very generous of you bud, not sure I'll ever be able to justify a Snap It set, a 10mm open end spanner used to cos £9 each over 20 yrs ago, been looking at the hub puller and copper end nut hybrid that one user made up, might have a go at knocking one up myself, went to try Beavis' idea with the clamp last night, but could only see a new caliper being required 10 mins later.
    yep.. pushing too hard without turning the piston is a deffo nono.....
    If you want to get the laser one ( avaliable from helfrauds for £20) then i'll mod it for ya..
    Nicking Ya Dinner.
    Thats two more motor factors tried, one has a set for £190, all others it's a Ford one only, where did I put that Skoda brochure down to.
  1. Brakes advice
    By Angel1368 in forum Handling & Braking
    Last Post: 4th May 2012, 18:39
  2. 06 Vectra est 1.9cdti Sri 150 brakes advice pls
    By lgtuk in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 10:07
  3. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  4. New brakes time any advice
    By aldo in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2006, 19:27
  5. advice on disk brakes
    By markspark in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2006, 18:04
