Thread: Thermostat issue?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Thermostat issue?
    Since the cooler wather has arrived ive noticed my temp gauge sits at about 85 when driving around town but if i go on a faster road or put my heaters on the temp drops to about 75.I remember reading somewhere that the gauge should read about 85 ish all the time.
    Does this sound like a duff stat? or is it normal for a veccy?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    hi ive got a 1.8 ls 04reg the temperature gauge would only go to 75.but when you are stuck in traffic it would rise to 90. when you are out of traffic and on a run the needle would drop back to 80. what made it worse when you put the heater button on 2 or 3 the needle would drop down to a flat 70.you still get heat but not hot.i fixed it by getting a new thermostat and now the needle rises up between 87 and 89 and stays there.also the heater is a major improvement and so is the mpg . i hope this helps
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    if its petrol when starting from cold the temperature needle should go to 87 to 89 in 2.5 miles of driving make sure your heater in off if it hardly moves it needs a new thermostat
    mine needed a new one at 53000 miles
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    diesel} takes around 6 miles to get to 86 -87 and the needle stays there
    { petrol} takes around 3 miles to get to 87-89 and the needle stays there
    depending on weather and speed doing
    if you turn your heater on and the needle falls back to 70 to 75 its broke
    i know because mine broke
    It's a diesel, from the profile, sounds quite normal
    Mine has always done that
    When driving it eventually reaches about 90
    When stopped it intially rises then falls to about 85
    Turn the heating on full blast and it can fall to about 75
    You're not likely to notice this during the summer
    Aug 2011
    Basingstoke
    Trim : SRI
    Thanks,
    yeah mine is a diesel and boy does it take a while to get upto running temp lol
    I thought it might be goosed,it was also explain why my MPG is a bit poor.I noticed as the weather started cooling that my fuel consumption started to rise.
    Looks like ill be wearing an extra jumper in the car and will also advise the misses and nipper to as the heater will be on cold untill i get it changed lol
    Aug 2011
    Basingstoke
    Trim : SRI
    Mine hasnt reached 90 in about 3 weeks,the last time was when i got stuck in traffic and the tousdie temp was 26 degrees,now the outside temp is barley reaching double figures.
    Do i have to change the whole stat and housing or can i just take it apart and do the stat?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
  1. new thermostat
    By wildchild in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2012, 14:02
  2. Thermostat Issue??
    By KeeronMac in forum Diesel Engine related
    Last Post: 11th March 2012, 20:55
  3. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  4. Thermostat Issue?? Or Something Else
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 18th January 2012, 22:58
  5. Thermostat
    By shrekster in forum Engine & Drivetrain
    Last Post: 26th January 2009, 01:40
