Results 1 to 10 of 16
Thread: Vectra C SRI Alarm
    Regular Member 150_SRI's Avatar
    Sep 2010
    Lincs
    Default Vectra C SRI Alarm
    I have a new vectra C and the alarm is not sensitive at all, i can boot the wheel or bang on the window and it wont go off at all, any know if the sensitivity can be altered?
    Also, i managed to make the alarm go off by when i jacked the car up. But the alarm was more like a sqeel than an alarm. I heard a SAAB Alarm recently and i was really loud, im pretty sure the alarm on the saab uses the HORN on the car as the alarm as the noise was the same. Does anyone know if the vectras alarm can be hooked up to the horn so the alarm is louder?
    Thanks,
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    The alarm siren is in the boot hidden behind the left hand boot trim (behind the Fuse box) If you open the trim you will see the connector on the back of the siren. Disconnect it and the body control module on the car then resends the alarm siren thru the main car horn. 10 times louder, the only problem on the dash each time you put the ignition on an Alarm fault will register in the display. No problems just cancel the fault each time.
    Quote Originally Posted by tangoman View Post
    Disconnect it and the body control module on the car then resends the alarm siren thru the main car horn. .
    Deosn't work on all Vectra's though.
    As for the sensitivity, it's not designed to go off by kicking the wheels or thumping the window. If it was, then it would go off every time a lorry thundered by it. It's designed to go off if a door or the boot/bonnet are opened, or if any of the glass windows are smashed - which trigers the ultrasonic movement detectors.
    Sep 2010
    Lincs
    Hi Guys, i have tried to access the section where the siren is in the boot but the carpet doesnt seem to want to pull back. Anyone know the best way to access the siren?
    I thought maybe putting the back seat down and getting in there, bhut didnt seem obvious. Cheers,
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    its in the little cubby hole on the lefthand side in the boot ...... where the fuses are ...the alarm is a bit further along.
    This worked on my 04 sri ..but it doesn't work on all full cambus cars
    Sep 2011
    Sipson
    ... the only problem on the dash each time you put the ignition on an Alarm fault will register in the display. No problems just cancel the fault each time.
    Thanks for this, I get the warning everytime but could not find a fault with my system, and have yet to hear the alarm go off, hopefully it is as simply as the plug being pulled from the speaker in the boot.
    Sep 2010
    Lincs
    I have pulled open the compartment on the left side in the boot and can see the fuse box, but cant see the siren, is it possible to access the siren from here?
    Sep 2011
    Sipson
    from memory, atleast on the pre facelight, the fusepanel is forward of bay/pocket, the siren is visible behind hit, i.e. between the light cluster and the fuse box.
    Sep 2010
    Lincs
    I had a look at the fuse box in boot, but cant see how i can get my arm in to disconnect the cable and cant see the siren from here, do i need to remove the carpet, anyone gt any pics to do this?
    Sep 2011
    Sipson
    IIRC, it should be visible, I will check mine when I get home tonight as I want to see if I can plug mine back in, assuming it is unplugged.
    Or you can just see it here: http://www.vectra-c.com/forum/showthread.php?p=1460086
  1. Vectra Alarm
    By davidallanmcdonald in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 11:41
  2. vectra c alarm
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2010, 21:25
  3. Vectra Alarm
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2010, 13:15
  4. Vectra C Alarm
    By Electricdave in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2009, 23:19
  5. Vectra alarm
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2009, 13:32
vauxhall vectra alarm fuse
vectra c alarm fuse location
vectra c alarm siren
vectra c siren disconect
2006 vauxhall vectra sri how to arm alarm
vectra c alarm fuse
where is speaker in boot of vauxhall signum for alarm
