Results 1 to 10 of 16
Thread: ice thread part 2
    Aug 2011
    salisbury
    Default ice thread part 2
    please see http://www.vectra-c.com/forum/showthread.php?t=148231 for my firs install attempt i had the issue of my sub falling over and i broke my phono leads in the one of my amps so i needed to modify all pictures will be added then ill edit and talk through what ive done as i dunno how to type between pictures
    well that didnt work so i added feet from back to front with the back part cut out to fit in the slanted plastic bits in the boot
    then cut out some laminate flooring to make the box effect and screwed it on
    the horizontal is not cut straight but i will explain that at the end
    put it in the boot and you can see the gap down each side ill come back to this
    i put the amps in altho only 1 will be wired in due to breaking some of the wiring from the sub falling over
    as you can see from the shelf i took out the metal supports not intentional but its happened so ill explain plain at the end please see http://www.vectra-c.com/forum/showthread.php?t=146995 for how this went
    nxt you can see the cover for amps and the sides that are added to tidy up the box i need to adjust these to help keep the sub sturdy
    right the plain is glue the 6*9 speaker wires int the parcel shelf
    run more wires to enable other amps
    carpet the box step
    add lights to the steps this is where the not straight cut will help as i want the lights to be tilted towards the sub
    the lights will be connected to the boot light so will only come on when boot open
    what you all think ?
    Aug 2011
    salisbury
    and id like to add half this was done in the dark
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Wow that's a big kit you got reinforced glass on your mota like?
    Aug 2011
    salisbury
    the windows are not my worry i need to find away to stop the the boot vibrations/rattle when the boot is closed
    May 2011
    bispham, blackpool
    wow nice are you using any power caps.
    years ago when i had my escort cab i was toying with the idea of a split charge relay like they have for towing caravans and a seperate battery to run my ice and i was running only 2 amps 2 subs
    i was allways worried that my alternator wouldnt be able to handle it all
    Aug 2011
    salisbury
    Currently not just running the one amp off the battery I did have another amp bridged from the first but I didn't like this so am waiting till payday, currently looking at better ways to keep the amps powered
    May 2011
    bispham, blackpool
    Quote Originally Posted by danno91 View Post
    the problem i use to have when i use to have all this was when i had everything on heater lights etc with 2 amps the bass wasnt as clear and distorted a lot during the day it was fine this could ov been because i was driving a 20year old xr3 so not sure if alternators are any better these days
    my theroy was put a lesure battery in the boot and just run the amps stright off this you buy a split charge relay and what this does is switch the charging from main car battery to 2nd battery when its getting low so the alternator wont be getting worked as hard with all that load on one battery.
    i bought all the stuff for it but never got round to try it out and then the 3rd child came along and it was good bye convertable hello to vectras mondeos etc now my little one doesnt have a buggy anymore so maybe one day i might get back in to having a ice install in the boot
    also you will only need the one 12v cable going from the front to the back this way so you still will be able to wire more amps up on their own with less wires running through the car
    Aug 2011
    salisbury
    Quote Originally Posted by 6009tristanb View Post
    That's defiantly worth looking into I still have buggies going in my boot tho so I'll need to consider what little space I have left lol
    May 2011
    bispham, blackpool
    well its worth a think about once you conect them all up turn everything on in the car and see if you notice any difference like i said not sure on how good todays alternators and batterys are like
    the other option is the power caps for each amp and you will have the space at the side of your box for them
    Aug 2011
    salisbury
    I've just looked into the cost of this and it is not that expensive so now all I need to do is work out where I can put the battery I was thinking of cutting the floor and putting hinges on it so I can easily access the spare wheel so I will need to take that into consideration as well
  1. That thread with fitting guides online by part numbers..
    By Old man Jimbo in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2009, 23:22
  2. Replies: 70
    Last Post: 15th October 2008, 18:51
  3. My busy week part 3 (3rd & final part ;)
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 17:13
  4. Bring back the Krays (thread split from scam thread)
    By VauxVeteran in forum General Chat
    Last Post: 26th July 2006, 09:58
