Thread: 888/vxr suspension kit
    Leicestershire
    Question 888/vxr suspension kit
    having now had my 1.9cdti 150 elite remapped by 888 i am quite keen on sorting out the wallowy soft handling.
    Has anyone on here had the vxr level 1 suspension kit fitted by 888 ?
    I believe they put on new springs and dampers that lower the car by 30mm for £500 - 600.
    Would this still give me an acceptable ride comfort as i do around 35,000 miles a year and don't want a super hard ride
    cheers
    You need to get hold of 'spoons' mate..
    He's got the VXR kit on his car..as has Plasma..
    either of them will be able to help you out..
    spoons
    Guest
    OK, I'm sort of here first then....
    I've only had the Eibach 888 lowering springs and I found the ride quality to be absolutely fine... no problem at all...
    However I dont have the dampers yet as I'm still waiting for 888 to call me about a date to fit them !!!
    I've been told that the dampers will also make the ride firmer, but not to much.. if this is the case, then you should be fine
    EDIT: It is most certainly NOT a hard ride... and I've got 19" wheels as well..
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Ok, looks like I'm last then. What Spoons said sums up my findings on the 888 springs. Same sort of ride as the SRi type springs but just a tad lower. I do over 20k a year with a load of town driving and the ride feels pretty ok to me even with the 19's.
  1. suspension
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:40
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. suspension!!
    By leonvectrac in forum Handling & Braking
    Last Post: 11th September 2008, 23:20
