Results 1 to 10 of 13
Thread: Heated Mirrors
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    Default Heated Mirrors
    Should an 06 SRI have heated mirrors?
    Feb 2011
    Selby
    Yep, all Vectra Cs do. They come on when you put the rear screen demister on.
    Mar 2011
    Northern Ireland
    thanks!
    a bit unusal for them to com on with the rear demister, but I'll give that a go.
    I had noticed this morning that the passenger side mirror was fogged over and did not clear when driving and wonder if I actually had heated mirrors
    newport
    glass may have been replaced at some point, thats the issue i had with mine, one would demist the other wouldnt. popped the one glass off, and there was no element on the back of it, and 2 wires, taped up tucked in behind it. £10 later on ebay for a heated glass, and 30 secs of fitting and job done
    Quote Originally Posted by Paul_NI View Post
    Not really. Vauxhall have done it this way for ages.
    IIRC, my 91 Cavalier had a separate switch on the mirror control, but my 93 Cavalier came on with the rear demister. After 15 mins it will turn itself back off again.
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    Every single car i have owned has had the mirrors working with the rear demist..... when I did car sales, never once saw a separate switch for mirrors.... maybe i'm being blonde tho
    Sep 2010
    It's certainly normal,.. even my Alfas did this. The assumption is if your rear window needs de-misting then your mirrors certainly will. Just watch the vapour rise when you turn on the rear de-mister
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    I had 2 Astra estates, one a J reg, one an M reg, both had a small button & led light on the mirror control switch which was to turn the electric mirror heaters on, ive always found that you get odd lines on the inside of the rear window when you put the rear window heater on when its not needed.
    Feb 2011
    Selby
    It's just down to the manufacturer's choice.
    On the Nissans, Mitsubishis and Subarus I've owned, it's a separate switch. On the Rovers and Vauxhalls, it's combined with the rear screen. I prefer a separate switch too, as often you want to heat the mirrors to clear droplets of rain, whilst the rear window is clean and dry so you don't need that heating.
    Not convinced the mirror heaters work on my Vectra anyway - but I'm not bothered enough to take the glass off and find out if the elements are there.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    My Mk2 Cavalier was a separate switch, my Mk4 Golf was part of the rear demister circuit, and as such the mirrors can burn out easy if it's left on too long!
  1. Heated mirrors
    By dhwigston in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2012, 10:56
  2. heated wing mirrors
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 14:00
  3. heated door mirrors?
    By bigdan03vfr in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 17:21
  4. Heated mirrors
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 23:49
  5. Heated Door Mirrors?
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 21:45
