Thread: Manifold Cracked
    Regular Member Cruize's Avatar
    South East
    Default Manifold Cracked
    Found a nasty crack in my exhaust manifold the other day
    Would explain the power loss and smoke smell it started to produce.
    I've looked about but can only find turbo/manifold combo's for ££££
    Does anyone know where I can find a manifold on its own? I Dont need a turbo so really dont want to have to fork out for one if I can help it.
    For a 04 Vectra 1.9 CDTi SRi
    Cheers guys
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by Cruize View Post
    Cheers guys
    Unfortunately, I think it's an integrated unit and the manifold is not available without the turbo. I still have a Haynes manual so I can check later but others may confirm before that.
    No chance of getting a weld repair done on the manifold by an engineering shop? Obviously depends on how bad and where the crack is.
    South East
    I'll get a photo of it and see what u think. It's kinda starts between two of the branches and then just goes round to the base from there.
    If it's a whole unit that could be a ****** lol
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Its a 1 peice Turbo Manifold design. A brand new (not recon) unit is around £440 on ebay, plus you'll need another £30 -£40 for new bolts, gaskets, studs, clamps etc.
    And an aircon discharge and recharge.
    South East
    The turbo bolts into the Manifold so it wasn't that hard. I did wonder one being ally and the other steel it couldn't be one whole unit...
    I found a donor turbo/manifold assembly on ebay for cheap. Took it apart and threw the nakered turbo to one side then sent the manifold section off to my mate to be acid dipped to clear the crap out.
    Took the broken manifold / turbo assembly off my veccy and unbolted the working turbo from the broken manifold. Fitted the new gaskets etc that were required and bolted my working turbo onto the fresh donor manifold. re-fitted and job done saved a couple of hundred quid
    Well done with the economical fix and for coming back and telling folks know how you did it.
  1. Cracked tyres
    By R-man in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 22:15
  2. 2.2 head cracked
    By srikev in forum Engine & Drivetrain
    Last Post: 10th December 2011, 20:54
  3. cracked windscreen
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2008, 22:58
  4. cracked windscreen
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 22:25
  5. Cracked Alloy :(
    By Syvlie in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2007, 14:22
1.9 cdti cracked manifold
how much for cracked manifold vauxhall vectra 2007
