Thread: Droning sound
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Default Droning sound
    Hi, I've noticed a droning sound don't know exactly how to describe it but its like a humming with breaks seems like its coming from one of the wheels.
    I can hear it clearly on smooth flat roads, Anyone know if this is a common problem or is it my tyres??
    Ashington, Northumberland
    Wheel bearing. Classic symptoms. If it's a rear one, I have a brand new one going spare.
    Sep 2009
    luton
    Mileage : 100000
    How much do they cost parts & labour wise?
    Its also making a knocking sound going into bumps i think this might be the control arms or "Boomerangs"??
    Jun 2011
    Sunderland
    Check the arb bushes as mine was clonking away when i got it if i went over anything bigger than a fag paper. Checked the bushes and noticed one of the back ones was wore down so wrapped tape round the antiroll bar and tightened it up to check and problem solved.
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Might be your tyres worn on the inner edges as well...
    Regular Member ph67's Avatar
    Northamptonshire
    Agree with above - it could be unevenly worn tyres, or if not then it can be wheel alignment, my rear wheels had too much negative camber, caused a droning sound and wore the tyres on the inner edges - had the camber corrected but still have the droning 'cos of the tyres.....worth checking out before you start fiddling with wheel bearings / suspension.....
    Sep 2009
    luton
    Mileage : 100000
    Its was the tyre in the end, my passengers side rear tyre was worn on the inner edge and was making the sound i presume. Had just this one tyre changed to see if it was this causing the main noise.
    The noise is almost gone well its not as loud and clear as it was before the tyre change, Problem I've got is the noise is still there but really quiet now and have to have all windows closed and radio off to really hear it now.
    Should i change the drivers side rear tyre aswell?? theres no inner edge wear on that tyre
  1. Droning noise
    By HHH in forum Engine & Drivetrain
    Last Post: 18th June 2010, 20:36
  2. droning
    By tugger434 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 00:23
  3. droning from the front end....
    By markvec in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2009, 21:44
  4. Droning from front end
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 11:34
  5. Droning sound from front near side
    By Dio in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2008, 00:07
